Question about Mitsubishi Televison & Video
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - just replaced my lamp - no it turns on but just with sound then after like 1 min it goes off then i get my error color code 6 red lights and 1 yellow why is this ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Sounds like the psu. power supply unit. check the caps are not bulged
Posted on May 17, 2014
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
How to test fans on dlp tv I have pulled the video engine
Hello. Most fan problems are dust related, and only need cleaning. A can of air should do the trick.
Oct 14, 2015 | Mitsubishi WD-73738 73 inch DLP 1080p...
I HAVE MITSUBISHI WD-73640 AND ITS SHOW THE GEEN LIGHT BUT DOESN'T HAVE PICTURE OR SOUND
The first thing to replace is the lamp. Google your model number and "lamp" and you'll find several sites that sell them. It isn't difficult to replace yourself and isn't very expensive. Good luck.
Sep 25, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
4red and 8 yellow code flash
I cannot post URLs here. Please try go googling this: "WD-73738 error codes"
The first result looks promising
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
Remote control not working on the tv. Factory remote and cable remote
Hi, first try camera test (video below). If it is not transmitting a signal then it is defective. You should purchase a new one (link below.) MITSUBISHI 290P187020 TV Remote Control
Jan 04, 2014 | Mitsubishi WD-73738 Medallion 73 3D DLP...
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 73 inch wd-73738 no picture
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
Oct 21, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
My 73'' mitsubishi model #wd-73738. Is flickering.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Or try replace light engine..if the above solution won't work..
Feb 23, 2012 | Mitsubishi Televison & Video
Televison & Video Logo
233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
