Question about Garmin Fishfinder 140
Garmin echo 150 won't turn on - Garmin Fishfinder 140
  • 778 Answers
Hello, First check to see if you are getting power to the unit. If you are then remove the battery for 2 mins and then put back in. Try turning it on, if still doesn't power up then will have to be repaired.
Posted on May 17, 2014
Wont power up, i replaced the power cable with a new one and still nothing, dose the transducer need to be connected for it to power on ?
The PWR button also adjust the backlight of unit. Press and quickly release to cycle through brightness settings. All else fails call Garmin www.garmin.com/support
Mar 25, 2016 | Garmin Echo 100 Fishfinder
Garmin 100 echo stays in simulate mode. Is there a setting to change it to live mode?
1 turn off the simulator in the menu.
if that does not work
2. Check the connection to the transducer, if it is unhooked or corroded, clean and reattach the connector, the unit will stay in simulator mode if it does not detect a transducer attached to it
Apr 21, 2014 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Echo HC-150 rebuilt the carb, and now the primer bulb sticks and engine won't start
Try to pressure test the carb to see if you have an internal leak. If it won't hold pressure then it is junk and needs to be replaced. If it holds then double check that you didn't accidently put the gaskets and diaphragm in wrong. If it holds and still doesn't work right replace the carb anyway. They are relatively inexpensive
Jan 20, 2013 | Echo HC-150, Hedge Trimmer 20"
Bluetooth is echoing and squelling
Turn the volume down and will not cause feed back.
Sep 09, 2012 | Garmin Nuvi 1400 Nuvi 1450 Nuvi 1450 Nuvi...
How do you get the echo 300c out of demo
You might want to post this question in a different section. This is the computer section.
Jul 22, 2012 | Garmin echo 300C Fishfinder
I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Jul 18, 2011 | Echo Garden
Caller gets echo of own voice wnen using bluetooth
Because this GPS was manufactured really bad is why that happens.
Before its too late I'd get a refund right NOW!
You are 1 of 5 other 660 GPS problems.
The only GPS problems are the same 660s
Hope this helps - Josh
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Fishfinder 140 Logo
281 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
