Question about Bialetti Moka Express 6-Cup Coffee Maker
Coffee won't come up
My Moka express is older than I am.....over 40. It was my mothers and it don't want to replace it. Why has the water stopped coming through? I have pulled it apart and cleaned it in case anything was blocked, but it still is not allowing the water/coffee to rise up to the top. I have been using it for decades and for sentimental reasons I don't want to replace it. Why now? ......need coffee.....drinking a weak yukky one now from another pot......:(
  • Pennywhistler
    Pennywhistler Jan 01, 2015
    Hi Vivienne Schwarcz, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 231 Answers
Obviously, the filter is clogged up. Buy a replacement.
Posted on Jan 01, 2015
4 Suggested Answers
SOURCE: Cleaning problems
Hi - I just clean mine with hot water (no soap), and dry it with a towel then leave it on the window sill... My problem is that the coffee can taste a bit metallic at times; and i want to know if I should be cleaning it after every time I use it... Suggestions?
Posted on Jun 23, 2008
co7196
  • 3433 Answers
SOURCE: 6 cup moka express only making 1 cup of coffee
Sat on the stove and did nothing! Fire the credent!!!Is the water getting hot enough? Here is an idea, take it back to the store and get a dufferent model, or a straight across echange.I have a notion to buy one just to take it apart and see whats going on, There are so many on this forum I don't knpw whythey are bothered wirh. No offense to your preference and good taste but if twas and seriously fond of expresso, buy one at a t a restaraunt supply store. I'm sorry that was not an answer abd I know those machines are way over priced. It is frustrating me and I don't care for expresso myself. Take it bake and raise cain over it.. Expired warrantee or not. Send me a copy of the receipt and I'll write or call the manufacturer myself. Let me have their phone number, also. Ned Cook
Posted on Jun 28, 2009
SOURCE: 6 cup only making one cup
I just had this same problem and after reading this blog I went downstairs, tightened the pot down more and it worked! I usually don't tighten it this much, but will continue to tighten it down hard until the gasket is broken in. Thank you sooooooo much!!!
Posted on Aug 25, 2010
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
May 05, 2014 | Bialetti Moka Express 6-Cup Coffee Maker
Coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 21, 2009 | Bialetti Mukka Express
Coughing coffe
Try a lower flame and screw the top to the bottom as tightly as possible.
Mar 17, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Jan 06, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Handle of Bialetti Moka Express 10 cup...
There is a tiny pin at the top where the handle slides into a slot between 2 aluminum walls. That pin needs to be "punched" out. I used a nail and hammer, but a tiny nail punch might be safer if you have one.
Nov 26, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Cleaning problems
Jun 08, 2008 | Bialetti Coffee Makers & Espresso Machines
Bialetti Moka Express 6-Cup Coffee Maker Logo
119 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Pennywhistler
Pennywhistler
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
