Question about LaCie F.A. Porsche (301177) Hard Drive
My new harddrive have bean formated and the capacity is only 262mb instead of 1tb can i change to 1tb again?
    Genius:
  • 1,224 Answers
You have to set parameter to high volume drive reform and go threw questions again set high volume
Posted on May 17, 2014
How to regain 1TB capacity ?
Suggest you save any data on the disk then do a full reformat of the disk, not the quick format.
Jul 29, 2015 | Matsunichi 1TB USB 3.0 Portable External...
Toshiba 1tb harddriver
Hi t rope
It sounds like your hard drive may be faulty, you can try another usb lead to see if this is the problem, otherwise the drive or enclosure may be faulty. Hope this helps.
Feb 19, 2013 | Toshiba 1TB USB 3.0 External Desktop Hard...
Setting the second sata hard drive as main drive
In your BIOS there is a section on Boot Priority. Set it to where it always boots from your 1Tb hard drive and this will make it the master. Another thing I did before I installed mine was to take the side panel off (computer unplugged) and remove the little CMOS Battery. That causes it to loose volatile memory and gives you a fresh start.
It worked on mine, but don't do what I did, closely observe which way the battery is turned. You can put it in upside down!
Jun 07, 2012 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
External harddrive formatted to be used as time machine for a mac, how can i reset it so i can use it with a windows laptop.
Open Disk Utility under Applications, Utilities.
Click on the external disc, click the box that says Partition, change Current to 1, then change format to MS-DOS.
Hit Apply and you should be good to go :)
Feb 17, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I just bought Lacie rikiki hard drives. As I put it into my computer the assistant starts. Unfortunatelly after few minutes the process stopped and the capacity is 465 GB instead of 500 GB. Is there any...
Hi.
This is normal. You will never get all the capacity for a USB key or a hard drive. The missing space is for format purpose and hard drive maintenance.
Hope it helps
Feb 08, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
Error message. not enough free hard disk space..i have a 1 tb external hd with only 30 G files on it
ok, right button click the 1TB drive within Windows Explorer,
How musch space is it reporting ? if this is incorrect I suggust you reformat the driver, first check the driver by using right button click on the selected driver , select tools then select error checking, now check the drive again,
Does the drive in question use a special driver ?
Regards
gewiz.co.uk
Nov 29, 2009 | Computers & Internet
1 TB Rock Mobile External Harddrive capacity
No. It is not that way. how it is read is as under: 1 K is 1024 bytes 1 MB is 1024 K bytes 1 GB is 1024 MB 1 TB is 1024 GB. As per books. BUT, when it comes to selling HDDs 1 TB is 1000,000,000,000 bytes. the extra 24 bytes at each lelvel have been overlooked. Thats where you loose so much of disk space.
Sep 08, 2009 | SimpleTech SimpleDrive...
OS partiton fails,resetup on NEW disc same problem
acronis seems at fault here.its better to keep one partion per harddrive.that way it is't jumping around as many times.use xp to do the partions and see if that works.also make sure *********** board can support the drives terrabyte capacity.also instead of useing the disk defragmenter built in xp use jk defrag it is alot better.you don't even have to install it just unzip and use.can even use off of a flashdrive.if you got any question feel free to email me at gamecrazy944@yahoo.com
Jul 25, 2009 | Computers & Internet
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Simpletech 1TB USB not recognised properly
I had a very similar problem. It turned out to be a faulty case.
If the drive was formatted, there is a very good chance you've destroyed your data and may need professional services to recover the files (if possible)
Chances are you just needed to replace the external case by removing the harddrive from the simpletech case and installing it in a new case.
But again, if the drive's been formatted, it may have wiped out your data.
Jan 22, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
LaCie F.A. Porsche (301177) Hard Drive Logo
46 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
