Have a Staples Model SPL-727MM paper shreader that won't work. Probably jammed, but unable to open it. Found some screw holes in where the tray pulls out, but regilar screwdriver won't fit, too long. Does anyone know how to open this type shreader.
    Top Expert:
  • Office Equip... Master
  • 36,408 Answers
Some home office shredders have the shredding mechanism "permanently" attached with only the bin (tray?) removable. The entire machine has to be inverted to gain access for cleaning. Periodic cleaning is necessary maintenance as shredders of this type are not self-cleaning.
Posted on May 17, 2014
  • 42 Answers
SOURCE: Paper Jam HP Color LaserJet 2840
Pull out the drum cartridge by it's green handle then
look for your paper at the timing roll section-there is a plate you can lift or release to access jams.
other than that the fuser unit on the rear of the mfc can be pulled out by moving two levers.
Posted on Jun 19, 2008
  • 7 Answers
SOURCE: Fake paper jam
I am running Vista Ultimate SP1 x64 all updates and have been trying to sort out the fake paper jam on my Epson R300. I tried compressed air from my workshop compressor; believe me if anything was blocking the feed it wouldn't after I blasted it lol! anyway I also tried running some thick card through and still nothing, did some button pressing to get out of maintenance errors and all sorts of other things. I was about 5 mins away from reluctantly scrapping the printer when I happened across SSC Utility.
I downloaded SSC Utility, but there didn't seem to be much that would sort out the paper jam so out of curiosity I decided to click a few things and then test the printer.
The only thing I ended up Clicking was 'Reset Protection Counter' and that worked, it printed out fine.
so that was my solution, we'll see how long it lasts.
Posted on Oct 07, 2008
SOURCE: photo tray doesn't work
hp f 4235
Posted on Dec 25, 2008
  • 685 Answers
SOURCE: I have a paper jam
On that printer, you can't pull out the main tray. This video shows how to clear a paper jam on the C7280.
Posted on Jun 17, 2009
  • 86 Answers
SOURCE: hi, my lexmark T640 is saying 202.06 paper jam,
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Posted on Oct 20, 2010
Staples mailmate SPL 727MM will not power up
Shredder refused to power on. No light... nothing.
1st step: (MAKE SURE THE THING IS UNPLUGGED FROM 120 V FOR FOLLOWING STEPS)
So, i dismantled it according to previous postings and inspected visually everything. Nothing had heated, all solderings were OK on the boards. Did few checks on the interlock drawer switch with an ohmeter: tested OK. I removed the 2 screws holding the little board where the power on switch is mounted. Ohmeter said no action across switch prongs when i push the button. I drowned the button with tape head cleaner and activated the button a hundred times. After it dried, i repeated the operation.
It cured the problem. I Dont think these kind of switches can be found... cheap stuff.
Had some problem finding a 10 inches phillips screwdriver to open the case... Electronic store had one...brand is Xcelite.
....have fun challenging those China made gizmos !
Sep 27, 2011 | Staples SPLXC200D Shredder
Top cover paper jam in laserjet 4345mfp
check the top cover, all the trays of the printer. sometimes there are small particles of paper that is put in the trays or inside the machine.
Feb 25, 2010 | HP LaserJet M4345 MultiFunction Printer
Staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Sep 10, 2009 | Office Equipment & Supplies
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Staples shredder spl 727mm - quit working all of sudden - jammed?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}First, don’t destroy anything on the top of the machine.Eight screws. Two are accessed through the rubber foot pads. Six are accessedfrom the basket compartment. You will need a VERY LONG AND SKINNY Phillipsscrewdriver with a foot-long blade and a very narrow diameter to fit down theaccess holes. I cut my case in two to get at the six screws through the basketcompartment (very messy). It would probably be easier to drill holes throughthe bottom of the case for screw access. You could then use tape to cover the holes.
Our shredder quit running while in use. Staples said itwould probably need a new circuit board. Once I got inside I found a 5 amp fusesoldered to the circuit board. Yes, it was blown. I jumped it and the machineworked. I unsoldered the fuse and soldered in two wires that I ran through ahole I drilled in the top of the machine. I took a 5 amp automotive fuse(bayonet style) and drilled a small hole through each bayonet. I then threadedthe two wires through the two holes on the fuse and wrapped them around,instead of soldering, for easy future replacement. Then I wrapped the fuse withelectric tape for safety and taped the fuse flat to the top of the machine.Voila! A flawed Chinese product is made usable! Dan Phelps delps@charter.net
Feb 09, 2009 | Techko SH1524CP Shredder
The bottom paper tray of my PIXMA iP4500 (Serial No.AAVY39440) is stuck in place and cannot be removed in order to load paper. How can I free up the tray?
Fix for Brother mfc-440cn
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000010859&Sympt=I+am+unable+to+pull+the+paper+tray+out+of+the+Brother+machine.+What+can+I+do%3f+stuck%2c+jammed&Model=993&ProductGroup=5&Keyword=tray
Sep 30, 2008 | Office Equipment & Supplies
Paper will not feed through machine
Brass screw is probably the chrome packing screw which normally sets in a hole near the front of the copier when you open the "**** shell" Paper pick up could need feed wheel. clean with fantastic or soap and water and see if it helps. Also on this model check your exposure lamp is it coming on, if not it may on flicker, On all these PC when the lamp goes bad the paper jams usually at turnaround. Good luck.
Jul 07, 2008 | Canon PC-795 Copier
STAPLES MODEL#SPL-826XSHREDDER
Cleaned the sensors with warm water and Q Tips. Works fine now..
For Staples shredder model #SPL-826X.
Thanks!
Apr 29, 2008 | Achiever SCS-6 Strip-Cut Shredder
41 people viewed this question
jasbo
jasbo
