Question about Makita Saws
How do I wire both start and run capacitors to a 7.5 HP electric motor. There are 2 start & 2 run capacitors in the system.
  • 3,600 Answers
Need to know the brand of motor ac or DC 220 or 440
Posted on Jun 25, 2009
I have a waterway 115v, 2 hp 2 speed pump that starts in the low speed setting but hums in the high speed setting. replaced the starting capacitor, checked the starting switch and governor, both ok
perhaps you should take it to motor shop ( google motor rewind and repair in your area).. Electrical motors that run in water should be repaired by insured shop.
Apr 06, 2018 | Waterway Pool & Spa
Do manufacturers of electric, cap-start/cap-run, 1ph motors use a standard wiring code for the capacitor wiring?
probably not as different manufacturers use what ever wire is available at the time of manufacture
however there is a standard attachment method for the capacitors and that is the diagram that you should be seeking
for example-- many capacitors have two lots of connected terminals and the motor will have only 2 wire ,so connection is to one each of the terminals that is not connected
others have 3 wires so one wire on one terminal and two wires on the connected terminals
This is knowledge that motor repairs will have learnt in their trade so it may be advantageous for you do do a lot of home work on power
Apr 04, 2017 | Heating & Cooling
Motor stall
if the motor has 3 phase ( test the terminal motor for voltage) if there are the motor need repair, brushs, ball bearing, or winding faulty)
2) if the motor is 1 phase, the capacitor or centrifugal switch is faulty or windin run or starting can be faulty. However in ANY case try to TIGHT ANY wires loose or connector, or corroded contacts in the relais or contactor, clean with alcohol isopropyl or c.solvents.
God bless you
Nov 07, 2013 | Psi Ar Vip Electric Pressure Washer: 110...
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Wiring of 2hp motor
You need to take advice from the motor manufacturer or reconditioner to ensure you are wiring it correctly.
Typically a basic single phase motor will have a start winding and a run winding. That usually makes four wires for a reversible motor but that can be cut to three if the motor must run in one direction only so the three wires would be start, run and common.
The run is connected to the hot side of the supply and the start similarly connected to the hot side except the start capacitor will be in series. The common wire will require connecting to a neutral and of course the motor body will need a ground unless it is double insulated.
It should be possible to sort which is which using a sensitive ohmmeter.
Jul 03, 2017 | Smith 2hp Pool Pump Motor A O Electric...
1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Aug 23, 2009 | Drills
Fan runs, compressor tries to start then kicks out on overload.
i am not familar with this model number..
1. are you using the right type of capacitor. you need a "start" capacitor not a run capitor. make sure that capacitor is the proper size.
2. have you tried a hard start kit?
3. is their oil in the new compressor?
4. was the old compressor for r-22 or 410a?
5. is the new compressor for the proper refrigerant?
6. is there refrigerant in the system?
7. is it wired right?
8. is this a heat pump? if so is your reversing valve operationing properly?
9. was the old compressor a mechanical or electrical failure?
if electrical did you install a new filter drier?
10. just because the new compressor is new does not mean it is good
11. do you have the proper voltage?
good luck
hvac teacher
Mar 23, 2009 | Goodman GMS90703BXA Heater
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Saws Logo
94 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
