Question about GE Dryers
Does the GE DBL333GB2WW gas dryer have a moisture sensor?
  • Joe Lyons
    Joe Lyons Jun 01, 2014
    Thanks, jrez143!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Look inside on the backwall of dryer if you see some small holes separate from many holes where the heat comes in yes you do
Posted on Jun 01, 2014
jmgldsmth
  • 2005 Answers
SOURCE: How do I take off the front panel of dryer so I can install new coils
There are no coils in a gas dryer only an ignitor and, gas valve
Heating coils are only on electric dryers
Posted on May 22, 2009
localwonder
  • 6784 Answers
SOURCE: heat shuts off way before clothed are dry
Check the following to address this issue. replace the sensor if all below checks out to be OK.
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
Replace the sensor (located near the igniter) if found defective.(Flame sensor).
Posted on Jun 03, 2009
delpolito54
  • 44 Answers
SOURCE: check continuity on a flame sensor
flame sensor is closed when dark, open with the ignitor light. Thermostat is closed when cold, open when reach temperture. Ignitor is a closed circut but high resistant value, put your meter on 10k. Also to the gas valve 110volts be carefull.
Posted on Sep 01, 2009
  • 572 Answers
SOURCE: Kenmore gas dryer - Running dryer while empty and
ur vent might be clean but also make sure its not long enough that makes ur dryer hard to get the heat out fast enough
Posted on Feb 09, 2010
ftw1952
  • 10319 Answers
SOURCE: moisture sensor
Yes it does
Posted on Apr 15, 2010
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
Samsung frontload gas dryer DV218AG moisture sensor doesn't work properly. Dryer adds minutes to drying cycle even when cloths are completely dry.
Clean the sensors with windex or like cleaner. Farbic soften can build up on the sensors and cause you trouble, Also, the time displayed is an estimate not actual drying time.
Jan 26, 2014 | Samsung Dryers
Ge dryer model dhdsr46
There should be two tabs on the back wall that look like metal strips. Those are the sensors and they rely on the clothes to touch them every so often to get and idea how moist they are. The sensor is most likely not the case. You should check the wires to it but it is probably the control board
Jun 17, 2013 | Dryers
Amana dryer starts then stops
Sensor bars are contaminated with a moisture barrier of some sort. Dryness control is not detecting moisture. Solution: Windex the sensor bars and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2013 | Amana NDG8805A Gas Dryer
Dryer will not shut off. set on more dry
The problem is likely the moisture sensor has failed. They are inexpensive and easy to replace. Here is a link that should help Moisture sensor replacement
Oct 21, 2010 | Kenmore 73952 Gas Dryer
My dryer will not heat. does this have anything to do with the moisture sensor. Where is this sensor located ?
No, the moisture sensor only senses the wetness of the clothes and the computer determines how long it will take to dry the clothes. The no heat situation is one of 3 problems. No gas situation, high limit switch has tripped or motor contact switches broken. You will need a professional LG technician to diagnose the problem for you.
Good luck
Oct 01, 2010 | LG DLG7188 Gas Dryer
The dampness sensor on the ge profile gas dryer is off - is it possilbe to reset and turn back on?
The dampness sensor is just the two curved metal strips (about 5 inches long, and about an inch apart) located very close to the lint filter. (stick your head in the drum and look back down to your right) These strips can become coated with a waxy substance from fabric softener sheets which prevents them from detecting the moisture correctly. Just clean them off with a little soap solution.
Nov 04, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
May 21, 2009 | GE Dryers
GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Jan 24, 2009 | GE Profile DPSB620ECWW Electric Dryer
Broken sensor
In a GE dryer the sensor rods are below the front support and air duct assembly it may be that a wire has come loose or broken. The sensor itself may be bad but I would remove the front panel check wires before purchasing the part.
Dec 31, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
82 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
