I have a Sanyo DP19640. AFTER A FEW SECONDS WHEN TURNED THE PIrCTURE GOES BLACK BUT STILL HAVE SOUND? HOW DO I REPAIR?/ Parts gone ba
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Posted on May 17, 2014
5 Suggested Answers
waynejamescm
  • 67 Answers
SOURCE: Have a Sanyo Plasma TV
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Posted on Jan 10, 2009
javswr
  • 44 Answers
SOURCE: sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Posted on Mar 02, 2009
roety
  • 585 Answers
SOURCE: The picture on my TV goes black after few seconds
Hi my name is Roety,
I can help you with your issue ,
Sounds like a lamp going bad
No model listed makes it hard to guess here
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Dec 15, 2009
techman007
  • 1112 Answers
SOURCE: on a 32 inch westinghouse
HI:
Seems have no Y-Drive, Check and or replace the Main Y-sustain board.
Posted on May 21, 2011
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
I have a sanyo dp42848 tv the screen goes black after a few seconds but still has sound
The model listed here does not use a bulb or lamp and most likely not a do it yourself repair---consider having a shop look at this and get a estimate.
Oct 22, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
When tv turned on will get apicture for only a few seconds then screen goes black, but wil continue to have audio. Cannot pull up menu on tv either
Hello.The screen goes black means that the backlights of your LCD is not working.Maybe the problem is the power supply or the driver board of the backlights.They shutdown because there have a shorted parts on the circuit or power supply. Did you try to reset the power and turned on and get a picture or every time that you reset the power it will get a picture and the picture goes black?
Jul 02, 2011 | Sanyo DP19649 LCD TV
Sound on model dp19640 only goes up to 50%. need to increase sound.
Try to reset the tv by unplugging the power cord from the power outlet leave it off for 3-5 minutes. If that would not work try to call the tv manufacturer to have your tv warranted, either the manufacturer will replace or repair your tv depending on your warranty. If the tv is already out of warranty call the tv manufacturer still to get a service center that have an expertise in repairing such brand.
Sep 09, 2010 | Sanyo Televison & Video
Tv comes on for a few seconds then screen goes black still got sound is it worth repairing
proberbly not thats youre line output transformer gone it will cost you about 75 pounds to replace and repair
Nov 27, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Have a Sanyo Plasma TV DP50747 and both picture and sound all of a suden went. I turned it on from the remote and the green power light goes on, but no picture or sound and the power light goes off again...
Jan 10, 2009 | Sanyo PDP-42H2A 42 in. Plasma Television
Video goes black for a few seconds
This is a known problem for Sony and they have extended the warr into early 2010 to repair this series of HD TVs. Go to Sony web site and search for the info! No receipt is needed !!
Nov 13, 2008 | Sony KDS-R50XBR1 50" HDTV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
