My pPresario f700 turns on but doesnt startI will turn it on but it will not start but it won't turn off either does this mean I have a virus and need to take it in to a shop to get it fixed or does it need something else?
  • 778 Answers
Hello, It means either the hard drive or the operating system on your laptop is bad. Will have to put recovery disk in cd drive and reload software or if doesn't work will have too replace hard drive. Yes, sounds like needs too taken too the shop.
Posted on May 17, 2014
2 Suggested Answers
micromend
  • 748 Answers
SOURCE: Compaq Presario F700 keeps turning on and off
At this point I assume you've tried to go into SAFE mode, and into BIOS with no luck. You're right about the overheating but I think the damage is done. If the unit will no longer stay on in any mode or condition then heat has ruined something. First easiest part to check is memory. The check the CPU (most laptops still have a plug in CPU). If neither of these are suspect then take everything off the motherboard, including the screen (I use and external monitor). If the problem still exists then it's time to use a scope.
Posted on May 30, 2009
Why will my 2001 dodge ram not start ?
by start do you mean it won`t turn over or turns over but not start up. if you mean not turn over it could be weak battery, bad starter motor, bad wire connections. if you mean won`t start then it could be no spark, no fuel, worn out plugs, dirty or bad injectors.
Aug 23, 2014 | Cars & Trucks
99 f150 6cyl the problem started with it cutting out when i would take off or try to accelerate, then while driving it will judt die and now it won't even start without me spraying some starting...
just because the fuel pump clicks when u turn the key doesnt mean its not going bad, have you had it changed, or the fuel filter changed since u purchased the vehicle?
Oct 24, 2012 | Cars & Trucks
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
Compaq presario f700 ...Turns on and off repeadtly but won't boot up. Now If i hold ctrl,alt,del while it is turning on, the power light will stay lit but thats it.
Perhaps you have a virus. You would have to remove the drive and plug it into another computer using a USB cable. You can find these cables at newegg or tigerdirect. Once you have the drive connected to another computer, scan the laptop drive for viruses.
Dec 08, 2009 | Compaq Presario 700 470024-192 Notebook
It won`t start up I turn it on & it starts to
does your system have adequate ventilation? disconnect external devices, memory, expansion cards, hard drive and optical drive. then check if system will still turn off. if it still turns off, you will need to replace the motherboard. if it doesnt, try reconnecting the removed components one by one to determine which causes the issue.
Dec 03, 2009 | E-Machines eMachines Desktop PC
May 30, 2009 | HP Compaq Presario F730US Notebook
Fuji F700
If you mean while you're trying to take a picture, one configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
Jul 01, 2008 | Fuji FinePix F700 Digital Camera
Samsung f700 mobile phone
Are you sure its not loked??? The button is on the top right hand side
Feb 19, 2008 | Samsung Ultra Smart F700
F700 ringer vol
Really?? Mine is loud as hell I heard it ringing in my coat across the room
I think there is a way to change the volume but the button on mine doesn't seem to respond to touch When you first turn on ur screen there should be a lil bell in the top left corner Ive gotten it to work once It turned my phone silent but other than that it doesnt respond Ive tried using it while the keyboard was out to get it to switch sides but still no good You can try playing with that otherwise we'll all just have to make that long trip to profiles just to turn our phone volume up and down
Jan 03, 2008 | Samsung Ultra Smart F700
Computers & Internet Logo
David Payne
David Payne
