Question about Hoover FH50005 Quick and Light Steam Vacuum Cleaner
I have a hoover quick and light. I just recently used a homemade cleaner. Dawn soap and vinegar. I was cleaning my carpet and all of a sudden the machine got really quiet and stopped sucking up the soap. The brush still spins at normal speed. Any suggestions? Wondering if it is a mechanical issue since it runs quiet now. I think the only noise coming from it is the brush spinning. Also, does the homemade carpet solution have anything to do with it?
Soap and water probably got sucked into the motor. I'd avoid using your homemade solution in the Quick and Light, maybe just use vinegar.
Posted on Sep 28, 2016
You have to take those type machines, as well as
vacuum cleaners apart, several times a year & clean
then out
Posted on May 17, 2014
Hoover Tempo Widepath: It appears the height adjuster may not be working correctly; while pulling the vacuum toward me the brush skips across the carpet now displaying a diagonal pattern in doing so. I...
Check height adjuster first to make sure that it is still functional. If the brush is too low to rug, it can cause some skipping as you pull the vac. to you. Have you tried to vacuum at a different angle to see if skipping stops? If your height adjuster checks out okay, it could be that your rugs may need a good steam cleaning. I have two dogs, and after awhile, the oil residue from there dander collects in the rug which is unavoidable after a long period of time with regular vacuuming. The carpet starts to mat and that's when I experienced my vacuum cleaner starting to skip. After a good professional steam cleaning of the carpets were performed, the vacuum cleaner stopped skipping. Hope this was informational.
Dec 20, 2014 | Hoover U5140-900 Tempo Widepath Bagged...
Why doesn't the water pick up on my carpet shampooer???
Hi Julie! If the cleaner is not picking up the dirty water this usually means something is not sealed off properly. Try these steps below to restore suction to your cleaner.
1. Remove the clean water tank. Recline the handle & let the handle lie down on the floor.
2. Remove the dirty water tank. Check that the dirty water tank cap is on the dirty water tank and tightened closed.
3. Clear the filter screen of any hair or debris.
4. Remove the nozzle. Clean the nozzle of any hair or debris.
5. Located on the machine behind the nozzle is a 2nd filter screen. Clean it of any hair or debris.
6. Replace the nozzle.
7. Replace the dirty water tank. Press down on all sides so that it is flush to the cleaner base.
Give it a try! The suction should be restored to your cleaner. If not I have included a video link where you may view these instructions. Hope this helps! Loss of Suction Won pick up Hoover Max Extract 77 FH50230 FH50222...
Nov 02, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
Why would hoover carpet cleaner make a loud noise, start smoking and now won't come on.
I'm afraid you burned a coil in the motor. And accidentally it stopped while that coil is between the contact brushes. Or one of the (or both) brushes are worn.
Sep 20, 2014 | Hoover Max Extract Dual V WidePath Carpet...
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How to remove nozzle for cleaning
Hi! We made the nozzle assembly easily removable for the Max Extract Dual V. Follow these quick steps.
Remove both tanks from the cleaner.
Lay the cleaner on its back while in the upright position.
Lift up rear edge of nozzle. Slide nozzle up and remove from cleaner.
I have also attached a copy of the owner's manual which has pictures if you need it. http://hoover.com/file/1088/
Hope this helps!!
Aug 13, 2014 | Hoover Max Extract Dual V WidePath Carpet...
Why is my retrieval tank light on when its empty hoover f8100900
Hi Tara! Try removing the dirty water tank and replacing it. If the dirty water tank is seated properly, you may have an issue with the sensor on the cleaner. We recommend taking the cleaner in to a Hoover authorized service center. Please follow the link to locate the nearest location to you. Thanks!
Service Center Locator
Jul 15, 2014 | Hoover F8100900 Platinum Carpet Cleaner
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How do I fix pin at bottom of clean water tank?
Replace the part. This might mean buying a whole new water tank. You can order most parts online. Have your make and model ready. Find a site by google. ie if it's a hoover enter, "hoover parts".
May 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
My max extract is making a whiring sound and i can smell rubber burning
The beater brush is binding in a locked up state. Probably by hair and carpet fibers. Dis-assemble and clean out any debris and change the belt/
Jan 31, 2014 | Hoover Max Extract Dual V WidePath Carpet...
Kenmore 85264 Electro Static Air Cleaner
I would recomend calling the 800 number to answer that question. I have this unit too and the instructions do NOT say to soak in Amonia and Vinegar! Good luck with that!
Mar 15, 2008 | Air Purifiers
Hoover FH50005 Quick and Light Steam Vacuum Cleaner Logo
223 people viewed this question
Top Hoover Air Purifiers Experts
Thatvacguy.com
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
