Question about GE GFSF6KKYWW 25.9 cu. ft. French-Door Refrigerator with 4 Glass Shelves, Gallon Door StoraDeluxe Quiet Desiand External Ice/Water Dispenser: White
Ge bottom freezer not freezing
The freezer is cold but will not freeze. Also the door ice maker, the ice was melting. The fridge are is still cold though?
    Top Expert:
  • GE Master
  • 12,962 Answers
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
Posted on May 17, 2014
  • 1122 Answers
SOURCE: Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Posted on Nov 13, 2008
  • 19 Answers
SOURCE: GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Posted on Jul 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
MNTECH
  • 1543 Answers
SOURCE: Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Posted on Oct 20, 2009
mrfixit3667
  • 262 Answers
SOURCE: Hi. I have a GE GSS22WGMC side by side and for a
you might have 2 problems. First I think you have either a defrost problem or a evaperator fan problem.
Look at the lower back wall of the freezer and if you see frost build up then you have a defrost problem.
also open the freezer door and press the door switch button that makes the light go off and listen for the fan. if you don't here the fan its a good chance that it could be bad.
I would wait on the ice maker issue until the cooling issue is resolved because it could be causing the ice maker problem.
If you dont here the fan then ckeck it in 60 min again and if you still dont here the fan it is mostlikley bad.
If you do have the frost then one of the following compontents could be bad: Defrost heater, Defrost limiter or the Defost Timer.
Posted on Jan 10, 2010
Testimonial: "Thank you. We were having the same problem and this post helped."
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GFSF6KKYWW 25.9 cu. ft. French-Door Refrigerator with 4 Glass Shelves, Gallon Door StoraDeluxe Quiet Desiand External Ice/Water Dispenser: White Logo
121 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
