Question about Brother MFC 420CN All-In-One InkJet Printer
Why does my Brother mfc 420 cn shut off and turn back in the middle of scanning
I tried scanning a document and the the Brother MFC 420cn shuts off and on in the middle of it. It doesn't allow me to scan. I have unplugged and shut off the device and it still doesn't work
    Sergeant:
    Champion:
  • 229 Answers
Have you scheduled routine maintenance regularly?
I believe it needs cleaned out
Posted on May 30, 2014
Maybe the printer needs it's software updated. You could try going to the Brother web site and check on that.
Posted on May 18, 2014
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-420CN
press menu then start b/k copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press start b/k copy: What two digit error code does the machine display? Post here again.
To leave the maintenance mode press 9 then 9.
Posted on Mar 07, 2008
  • 105 Answers
SOURCE: installation brother mfc 420 cn
For the drivers and manual, you can go to brother's website. Here's the link for your specific printer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc420cn_us
This should enable you to get up and running.
If you need something that is not in that group of downloads, you would need to contact Brother to order additional items.
Posted on May 20, 2008
leethedeuce
  • 4472 Answers
SOURCE: Problem with my fax Machine MFC 420CN
You can cancel a fax job that is stored and waiting in the memory.
1 For MFC-210C,
press Menu/Set, 2, 5.
For MFC-420CN,
press Menu/Set, 2, 6.
Any jobs that are waiting will appear on the LCD.
2 If you have more than one job waiting, press ▲ or ▼ to select the
job you want to cancel.
Press Menu/Set.
—OR—
If you only have one job waiting, go to Step 3.
3 Press 1 to cancel.
To cancel another job go to Step 2.
—OR—
Press 2 to exit without canceling.
4 Press Stop/Exit.
That should do it for clearing faxes you dont need you can also print off all the faxes in the memory and I believe that clears it.
Enjoy,
Lee
Posted on Jun 12, 2008
  • 159 Answers
SOURCE: Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Posted on Dec 24, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC 420cn "Cannot Init"
This is the Head Error 41
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Apr 25, 2010
Brother 420 cn won't scan to file
scan it to the image I have the same one
Jan 12, 2009 | Brother MFC 420CN All-In-One InkJet...
NEED HELP NOW!
you can purchase the ink here: http://www.brother-usa.com/accessories/Accessories.aspx?Model=MFC420CN&ACASCID=30
you can download the software for your Brother MFC 420 CN printer here:
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID={2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8}&NRORIGINALURL=/bsc/public/us/us/en/dlf/download_top.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc420cn_us&NRCACHEHINT=NoModifyGuest∏=mfc420cn_us®=us&c=us〈=en
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother printer MFC 420 CN
I wouldn't be surprised. Since you're going to need black ink eventually anyway, put in a new black cartridge and find out.
Sep 16, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother 420CN
switch off the printer..... remove the cartridges... gently clean the sensor area. re -fix the cartridges and switch on......
dont forget to rate this post.....
Aug 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Using MFC 420 CN;
yes, face down on the glass. it will scan first then send the fax.
Jun 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
OUT OF MEMORY
Try scanning at a lower resolution to see if this helps. It could be that the image is too compleax and filling the buffer.
Apr 30, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
80 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
