2010 mkx shop manuel - Computers & Internet
  • 778 Answers
Hello,Here is the download for your manual:
Posted on May 17, 2014
2010 lincoln mkx has mass air flow sensor code have replaced it twice unhooked battery for 10 minutes few days later code will return
I had a similar problem find fuse for the mass air system pull fuse and also pull fuse for computer wait ten minutes replace fuse for air mass system then replace fuse for computer this saves restting all your clock memories ,if the warnings come up again you will have to look further into the system looking for intermintent faultsor go to a service centre to have the problem rectified
Nov 02, 2016 | 2010 Lincoln MKX
How to fix 2010 lincoln mkx antilock brake system
The first thing you do is have a shop that has the needed equipment to scan the ABS system control module for fault codes (having these codes is crucial), then based on the codes received you perform the diagnostics to repair the issue.
Oct 25, 2016 | Lincoln Cars & Trucks
2010 Lincoln MKX factory sun roof does not close tightly.
Let Ford fix it? Get a price it may be simple or complex.
Oct 26, 2014 | 2010 Lincoln MKX
2010 Lincoln MKX Sun Roof is not closing tightly. Meeting a large truck will cause it to raise 1/4 inch and then has a loud wind noise while driving. Seems to have gotten worse in past 4 months. I c
The regulator is bad. Stretched cables, worn gears. You would have to remove the column bezels and the headliners to access the sun roof window. Replace the whole thing as you can't buy one without the other.
2010 MKX makes high pitch noise. can be heard inside and outside the car. What is it & How can I fix it?
This is just a guess but I can think of only two things to check.
Exhaust system has a small leak.?
Or fuel pump is about to fail.?
Jul 15, 2014 | 2010 Lincoln MKX
Natural gas smell from my lincoln mkx
Cylinder Misfires or a Rich Fuel mix,
that is overheating the Exhaust Converter
& giving you the smell
You have to correct the fuel trim or ruin the
converters
Need professional test equipment & take that
on a road test
A repair shop can do that
Don't need a dealer,nothing special
they do
Mar 12, 2013 | 2010 Lincoln MKX
I turn the key and it makes no sound on lincoln mkx
hold the key to start position and have someone tap the starter.
Sep 21, 2012 | 2010 Lincoln MKX
How do I replace the driver side side view mirror on a 2010 MKX?
SECTION 501-09: Rear View Mirrors 2010 Edge, MKX Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/16/2009 Exterior Mirror adobe.gif Printable View (126 KB) Removal and Installation
  1. Remove the LH front door sail panel.
  1. Disconnect the exterior mirror electrical connector and pushpin retainer.
  1. Remove the 3 nuts and the exterior mirror.
    • To install, tighten to 9 Nm (80 lb-in).
  1. To install, reverse the removal procedure.
Jul 06, 2011 | 2007 Lincoln MKZ
2009 MKX V6 has high pitched engine whistle, expecially when it is cold. May go away when at operating temp.
noises can be decieving--maybe a vacuum leak or a dried belt--cud be somethin internal too or alternator issues-get a repair book or let an honest tech listen
May 23, 2011 | 2010 Lincoln MKX
Computers & Internet Logo
David Payne
David Payne
