Question about Whirlpool Stove / Oven / Range Cooktop - 5706X570-88
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
I have a 2009 whirlpool model XFG371LVQ stove I cannot find an air adjustment for the top burners...The flame is orange, I removed the screws holding down tge burner and cleaned everthing there, It helped a little but I still think the burners are not getting enough air to them...The flames seem pretty high, but the repair dude turned the simmer down so that is good just needs more air to blue up the flame....
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
Posted on May 24, 2014
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: whirlpool stove top- two problems. 1) burner is
If all other burners working as they should, I'd check that bad one for partially plugged orifice. Try poking a small piece of wire through orifice hole to clean it. As far as igniter goes, and they are all connected to one source for spark, and separate wires run to each, make sure there is no breaks in small wire, as well as check that little ceramic igniter has a clean tip, if not clean with nail file or sand paper, and make sure it is same position at burner as others, as in close enough for spark to arc across to burner. if still no spark, try swapping wire with another, if it works, change wire, if not replace little ceramic piece at burner.
Posted on Aug 08, 2009
heatman101
  • 43501 Answers
SOURCE: Still yellow flame, checked the regulator pin is
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Aug 27, 2011
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
May 10, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Burners do not light consistently
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | Whirlpool GLT3034 Gas Cooktop
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Whirlpool gas cooktop will only spark on left front burner
i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Burner caps
Call a local independent whirlpool dealer. they can order the parts from a supplier, and most do not charge sipping as sears a.k.a. A&E will. And they will usually be less expensive too.
Aug 24, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Whirlpool Stove / Oven / Range Cooktop - 5706X570-88 Logo
256 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
