Question about Mantis 2-Cycle Tiller
Tiller will not start
I have changed the spark plug, air filter and put in new mixed gas, but it will not start. Any suggestions of what to try next?
    Problem Solver:
  • 6 Answers
Remove carb and disassemble to soak in carb cleaner. read my other resolved questions for more info.
Posted on May 28, 2014
    Problem Solver:
  • 23 Answers
There are several things that will prevent a 2-cycle engine from starting. The most common causes are no spark or no fuel. To check for a no spark condition, remove the spark plug, connect it back to the spark plug wire and while holding the spark plug boot, ground the spark plug against some unpainted metal part of the engine - usually the head. Pull the rope starter and observe if the spark plug is firing. You may need to do this in a dimly lit place to be able to see the spark. If you do not have spark, replace the spark plug and try again. If you still do not have spark your coil might be bad or the magnets on the flywheel may be badly rusted. Either way you must remove the engine to service it and may want to seek professional help.
If you have spark, try spraying engine starting fluid into the spark plug hole, reinsert the plug and try starting again. If the engine runs for a few seconds and then dies, it is probably running out of fuel and you have a problem with the carburetor. Remove the carb and carefully clean it by taking it apart, spraying it with carb cleaner and using a small wire about the size of a sandwich bag wire tie without the paper. Reassemble the carb and try again. Also check the primer bulb for a pin hole and replace if necessary. Check the fuel lines to see if they are cracked and replace them as needed.
If you have both spark and fuel and it still will not fire, you may have a severely scored piston, rings, and cylinder due to not running the machine with the proper fuel and oil mixture. You can use a screw-in compression tester to measure the compression of the engine. If it is below 90, you may not have enough compression to allow the engine to start. In this case the repair is much more intensive and even though you can buy a new short block, unless you are able to do this complicated repair yourself, it would probably be more cost effective to replace the tiller. Good luck.
    Problem Solver:
  • 5 Answers
If you left ANY gas in the carburetor for more than 5 months the carb is trashed. Do NOT buy a rebuild kit, it won't work. You need to but a new carburetor. ALWAYS run the engine dry before storing for more than a few months. It took me two new carbs before learning this.
Posted on May 27, 2014
    Guru:
  • 479 Answers
Check first whether you are actually getting a spark. Remove the plug, re-attach the spark lead and place the body of the plug in contact with the engine block. If the engine has a cowling which makes this difficult, you can use a socket from a socket wrench set or something similar to bridge the gap. Alternatively get an assistant to hold the plug against the engine with a plastic clothes peg. Pull the cord and check the spark is ok. It may be easier to see it in the shade or indoors (Don't run an engine too long indoors).
Problems with 2-cycle engines are often due to fuel flow issues in the carburetor. If the engine has a primer, make sure it is sucking up fuel. Look inside the tank and check that gas runs out of the return line when the button is pressed (the line without the filter).
Clogged jets can cause problems. These can be cleaned with a carburetor cleaning aerosol.
The valve in the gas tank cap can become clogged with particles of dirt. Check this is clear.
For a pictorial guide to cleaning a carburetor on a 2-cycle engine (used on string trimmers, chain saws, hedge trimmers and some lawn mowers), see my guide at the link below
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
Posted on May 26, 2014
2 Suggested Answers
  • 150 Answers
SOURCE: My mantis tiller has a
If the spark is weak, try disconnecting kill switch, still weak need new ign module
Posted on Oct 01, 2010
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Engine wont start. Changed plug; mixed new gas/oil combination. No start!
if you have a spark at the plug try cleaning the air filter, could be just dirty
Jan 07, 2011 | Mantis 2-Cycle Tiller
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
Petrol Engine will not start. The saw is a Stilh and I have not usaed it for 18 months
Ok first off drain all fuel out of the saw replace the fuel tank filter, then clean out the air cleaner, pull the spark plug out and with some and paper sand the spark plug so that it's clean. NEXT mix some new gas mix and add to the tank try putting the choke on full and pull rope about a dozen times then put choke in partial open and try starting. If it does not start pull spark plug and pull starter rope and see if you have spark if you do add a capfull of gas mix into the spark plug hole and tighten the spark plug down and try pull starting if it fires off and dies then you have a cracked fuel line and need to replace the fuel line. When you have the plug out spray a small amount of WD 40 into the sparkplug hole and pull the rope a few times to get rings lubracated then add the gas. If it won't start post here and I will give you more directions to test for starting again. HOPE THIS HELPS AND THANKS FOR USING FIX-YA.
Mar 17, 2010 | Garden
Slow starting tiller
Anytime an engine uses a gas/oil mix there is a possibility that the carbon this mix produces clogs the muffler making air flow next to impossible. First check to see if it will run better without the muffler. If it does you will need to clean the muffler by removing it and burning the carbon out with a torch. If this isn't the problem, then it may by your carb. Remove it, clean well with carb cleaner, replace the diaphragm if needed for as the diaphragm gets older it becomes stiff and will not pump the gas to the engine. When you reinstall the carb, turn the adjustment screws all the way in and the one and a quarter turns out to start with, making further adjustments from there after it starts. Hopefully one of these is your solution.
Jun 17, 2009 | Garden
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Oct 06, 2008 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
297 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
