Question about Worx Wg152 10-Inch 18-Volt Ni-Cd Cordless Grass Trimmer/Edger
Where is the charger location on the snipper? Cant seem to find where to plug it in--see nothing but screws but no receptacle
    Top Expert:
  • Worx Master
  • 35,601 Answers
The battery probably is removed and placed in a separate charging dock.
Posted on May 17, 2014
Is the centre screw in the rope start recoil spool a LEFT handed screw
cant find any info on unit about screw direction try removing it in counter clockwise if tightens go other direction or notify company about specs for recoil
Sep 06, 2016 | whipper snipper Garden
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
I do not have an owners manual for my Dalton power wheelchair. When hooking up the charger do I plug in the charger and then the chair or vice versa? And should the chair be turned on when its charging?...
You should plug the charger into the chair first, then into the wall receptacle. The chair should be turned OFF when charging. This will allow it to charge faster and completely. When charging is complete, remove the plug from the wall receptacle first, then from the chair.
Feb 26, 2011 | Health & Beauty
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Battary not charging
I have experience this problem myself however replacing battery and charger does not fix the problem. it seems to be something related the power receptacle (where you plug the charger in the laptop) the solution is to replace the part, but that can be expensive
what i did, as a workaround, is to plug firstly the end of the charger that goes into the computer and then connect the charger to the outlet this for some reason makes the battery charge.
hope it can help you
Oct 29, 2010 | Dell Inspiron 1525 Notebook
No power to the receptacles on a circuit, the breaker isn't tripped. there are no GFI's
No breakers are tripped and a circuit is dead.
There is a loose wire.
Let me explain how it works. Each 120V breaker has a black wire that leaves breaker box. The black wire is accompanied by a white neutral wire and a bare ground wire. These wires are sheathed in plastic, and altogether they make up a romex cable.
The cable leaves the circuit breaker box and travels to the first junction box. The junction box is a ceiling box that holds light or fan -or- a wall box containing switch or plug. As a general rule, the romex leaves the breaker box and travels all the way to a junction box located right in the area where lights and plugs are located. The romex does not stop at a junction boxes located in other room.
Inside the junction box, the romex splits and goes to the next junction box, and then to the next box, and the next.
So the plugs in one room are all connected together by a single romex cable that started back at the breaker box. And a single romex wire from the breaker box arrived at one of the junction boxes located in immediate vicinity of dead receptacle.
Here's what happened. A wire came loose somewhere between the breaker and the dead receptacles.
The loose wire is probably in a receptacle.
Here's what to do.
1) Breaker first: You can isolate the suspect breaker by identifying all other breakers. Then tighten screw on suspect breaker. Look for white wire and ground wire associated with the romex cable that connects to breaker >> tighten those screws on neutral busbar. Look for burning around suspect breaker. Is there a burning smell indicating breaker is bad?
2) Receptacles Next. Use ordinary tester. Test each receptacle. Receptacle has two rectangular prong holes and one round hole located below other two. The round hole is the ground. Breaker is turned on. Test each rectangular hole to ground. You have to test both prongs to ground.
The loose wire is right there in the vicinity of dead receptacles.
Test one receptacle and then move to next receptacle. At some point the tester will light up. Now click suspect circuit breaker to see if that receptacle is on breaker. Test receptacle with breaker off and breaker on. If that receptacle is on the suspect breaker, then a loose wire is inside that receptacle box >> or inside the next box. Many times, the wires are pushed into 'quick-connects' located on back of receptacle ... wires get loose ... you need a small screwdrive to release quick-connect, and then wrap wire around screw -or- replace receptacle
If none of receptacles show electricity, then loose wire is inside a switch box, or it is inside a ceiling box located in same general area. Check your switches first. Look for quick-connects, or signs of burning. Look for loose wire nut. Plug light into dead receptacle. Pull switch out with wires attaches. Power is on. Move switch around to see if dead receptacles shows electricity. Move to next switch. The loose wire is there somewhere.
Finally the ceiling box. Take down light and see if there is a loose wire inside. Look for signs of heat or burning.
Oct 11, 2010 | Connecticut Electric Square D Packaged...
Lawn hornet whipper snipper needs tuning
clean the air filter first of all and then take the spark plug out to make sure its clean (should be a light brown color)
if you need to tune it take the carby cover of and you will find two needles or screws marked H and L wind them both all the way in then wind the H out 1turn/wind the L out 1/2 a turn . this is a good starting point. Start the snipper then adjust the L screw minutely till it revs up quickly and doesnt bog down
Mar 18, 2010 | Ryobi Garden
My Isuzu Rodeo O2 sensor light is on and I would like to fix the problem.Could anyone tell me where is that sensor located at?
There's also a circuit on the back of the instrument panel that causes the O2 lamp to light every so many miles- I guess its a way to remind you to change the sensor. To re-set the O2 warning circuit, you must remove the instrument panel and locate a set screw on the back of the green circuit board. Remove the screw from the receptacle it's in and relocate it to the receptacle next to it. This will re-set the warning light.
May 08, 2009 | 1993 Isuzu Rodeo
Worx Wg152 10-Inch 18-Volt Ni-Cd Cordless Grass Trimmer/Edger Logo
42 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
