Question about Refrigerators
Whirlpool ED25DQ can you tell me the cu.ft and age? thanks ahead
4 Suggested Answers
SOURCE: WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
Possibly freezer drain blocked causing ice build-up behind back freezer wall. This internal wall should be accessible by removing screws.Check fan motor in that area is working and also check that all door seals have no cracks or tears. This can cause ice build-up and motor to run longer than normally. benham's suggestion another possibility.Naturally have power off when dismantling anything.
Posted on Jan 11, 2008
philbran
  • 242 Answers
SOURCE: Kenmore refrigerator and unknown capacity specs
It should be 25 cubic ft. It is usally the first few numbers in the model number.
Phil
Posted on Apr 10, 2009
SOURCE: looking for cu. ft. info on fridge - hotpoint
It's in the model number.
ctx14<---- 14 cu ft.
Posted on Feb 16, 2010
Whirlpool ed25dq Not Cooling
Unplug unit from the wall, remover the start relay from the compressor and shake it. If its solid possible bad compressor, if it sounds loose (broken part) then most likely bad relay. Verify your model number as you are missing some letters.
Good Luck
Dec 13, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can you tell me what year and capacity/ cu. ft. This Whirlpool washer is? Mod. LLR9245DQ0. s/n CF012468.
It's 3.4 cu.ft....and what do u mean by "what year" u used in ur question.
plz be specific.thank u.
Nov 23, 2012 | Washing Machines
Can you tell me age by model # Whirpool ED25SMXL 25.4 cu ft
Thanks you for your question.
The age of your fridge should be a 1993 made the 25th week of 1993.
The age is determined using the 2nd letter for the year and the 3rd and 4th digits represent the week it was built.
I hope this helps you. You can also visit the link i have provided for your viewing.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
Aug 24, 2011 | Whirlpool Refrigerators
I have a Whirlpool side -by- side 25 cu.ft. want to know about what age it is?
Hi.
It depends on the model number. Whirlpool started building 25 cu.ft over ten years ago and the model is still being produced. Please find the serial and number printed on the refrigerator service tag and give us the complete model number along with serial number. The model number will tell us the initial date of production, the serial number tells us the date of production of the specific unit. Here whirlpool date codes explained. To find the service tag check in locations illustrated below.
Aug 19, 2011 | Refrigerators
Duet front load dryer control locket light lit
Try holding in the "End of Cycle" button for 10seconds
May 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My water dispensor want work, I'm getting water, no humming when
Before you replace the switch have you checked the following.
Proper waterflow / pressure, filter condition, water line has no been crimped or bent, water line is not frozen.
Have you tried unplugging the unit and waiting a few minutes, plugging it back it and checking it?
I am sure these Q's may sound dumb, but I don't know everything you have already done. AND I hate to see people spend money on stuff they don't need.
Hope one of these help.
If so, please rate me.
Thanks,Matt
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Just purchased used 596.73824200 bottom freezer. Would like to know year manufactured and size in cu.ft.. Need lower shelf for freezer door. (Do not have a manual)
you can go here and find the parts you need. i really cant tell what age your refrig is by the model#  i believe it is a 24 cu ft. if you can give me a serial# off of the unit i can tell yo how old the unit is. thanks Peyton
Feb 18, 2009 | Kenmore 73822 / 73824 Bottom Freezer...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
