Question about Dewalt Drills
How to change the drill bit for a Dewalt DW995
  • 2,176 Answers
That tool comes standard with a keyless chuck so all you should have to do is grip the collar and turn it to loosen bit. If it is stuck you might try a rag of some sort on the collar and use the motor to loosen it up. Let me know if you need more help.
Posted on Jun 23, 2009
What is the best lubricant to use on my dewalt hammer drills please
It depends to where you want to apply your lubricant.
If you want to lubricate the chuck with the sds drill bit you simply add some cheap grease on the drill bit and the drill bit will slide easily on the chuck. On the other hand if you want to lubricate the sds drill machine then there is a special type super grease that you can buy from Dewalt in order to do so. Also since in order the super grease to be needed this means that you have used the drill a lot then also is needed to change o-rings, brushes and so on. So usually you have to ask for a service center to do it since they know how to do it properly and using the right kit.
Oct 18, 2014 | Dewalt Drills
DeWalt DW995 Type 1 cordless drill/driver. I took apart the drill for cleaning/lube and am having difficulty installing the "adjustment collar" into the correct position. There is a black mark on...
Alright, I hope you can follow me on this, it may be confusing. First, set the clutch coller on the clutch in any position. Use the collar to tighten down the clutch in a clockwise direction until the clutch stops clicking, then back the clutch off (1) click. Then take the clutch collar off and spin the collar until you see the little drill bit on the collar, line it up with the top of the drill as it would sit if it was put together, and gently set it on the clutch and spin it counter-clockwise a very small amount until it drops into place. Then you will see the drill icon is just offset to the left as it would be assembled. Then click it clockwise and the drill bit design is right at the top where it is supposed to be if the clutch is fully engaged. I wish I could make a video of this, it would be much easier.
If you have any questions, or need clarification, I will understand. It is far easier to do, then to explain.
Dec 06, 2010 | Garden
HOW DO YOU PULL THE CHUCK OFF TO GET TO THE GEARS INSIDE SEEMS TO BE STRIPPED OUT WANT TO TRY AND REBUILD MYSELF ITS A DW995 TYPE 4 MOTOR RUNS FINE JUST WANT GRAB.
if its a reversible drill,you open the jaws wide,and undo the left hand threaded screw inside the chuck,then put the the chuck tool in,and use that to unscrew chuck off the thread,right hand thread
Jun 29, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
Having trouble changing dewalt 14.4 v xrp cordless drill bit
hold black chuck and put in reverse if dont work spay wd 40 in and around where drill bit goes and let sit a few hours
Sep 12, 2009 | Dewalt Heavy Duty XRP 1/2" 14.4v cordless...
Dewalt cordless DW995 , 18.0V broken piece in side.Can't open.
A TORX I believe , if it is a 6 point star type screw hole? They are measured in mm I think and 15 and 20 are the most common sizes.
Mar 26, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do you change a chuck on a DW995. I took the center screwn left handed screw out. How do you back the old chuck out? how do you remove the chuck there is no allen key in the center of the chuck
position the drill to speed one & drill mode.u need a allen key then clamp it the chuck jaw close & tight. hit the allen key with hammer counter clockwise until its loosen. may have to do it any several times.
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
u need allen key that fit to the chuck. insert the short end to the chuck. tighten the chuck if u can. hold the drill at the edge of the table & smack the allen key counter clockwise. do it again if needed. but before u do it set the speed to #1 position & drill mode.thanx good luck
Jul 17, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Apr 12, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
1,502 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
