Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
How to remove write protection from dane-elec usb drive
SOURCE: Dane-Elec USB not working!
How I got it to work in XP Pro:
1) Plugged USB Drive in and saw it saw hardware manager install it but didn't see new Drive Volume in My Computer
2) Opened Control Panel
3) Open System
4) Clicked Device Manager from Hardware Tab
5) Expanded Disk Drives
6) Right clicked USB Flash Memory USB Device and hit Properties
7) Clicked Volume Tab and hit the Populate Button. Voila!
HTH
Posted on Jan 08, 2009
kamal1984
  • 1383 Answers
SOURCE: Not recognized by any computer
no it is supported on high speed or usb legacy 2.0
Go to bios setup and setr usb legacy 2.0 high speed
then save settigns
Posted on May 25, 2009
  • 1121 Answers
SOURCE: missing driver for dane elec 4gb usb flash pen
No zMate Pen driver is necessary to work out with Windows Millenium, Windows 2000, Windows XP and MAC OS 9.1 and more: they are plug and play.
but try this site:
http://www.dane-elec.fr/scripts/home/publigen/content/templates/TPL_ADV_INFO_C2_S4.asp?P=352&L=EN
Posted on Jan 11, 2010
  • 1584 Answers
SOURCE: My Dane-elec 4GB usb flash drive , no drivers?
Try it in another PC, if the same its a writeoff.
Posted on Mar 09, 2010
  • 51 Answers
SOURCE: Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
Posted on Mar 25, 2010
How do I remove the 'write-protection' on my DANE-ELEC 4GB flash drive?
if you are using windows as your operating system then follow these steps below
1.click on start 2.click on run and then write regedit or regedit32 in run window 3.next it will open a new window's which is Registry editor locate HkEY_LOCAL_MACHINE\SYSTEM\CURRENT CONTROL SET\CONTROL 4. Locate sub key storage device policies and then locate Dword value Write protect for disabling write protection you have to set value to 0 if it's 1 there !!!!
Sep 21, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Computer wont reed usb drive dane elec 4 gb usb drive
use a program called recuva (http://www.piriform.com/recuva) to see if you can pull any lost info form it. id recommend reformatting with hp usb format tool. if both those programs don't detect a usb drive its broken but you may get a new one form dane-elec if you contact their customer support. personal experience in replacing 4+ usb drives form lexar through customer care
Mar 08, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Hi, my dane-elec showing write protected. How can I solve it? I tried http://www.fixya.com/support/t345484-format_write_protect_usb_drive file but did not work. Need help. Thanks, Zia
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your SD drive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your SD drive.
May 04, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Don't know how to use it, can't find instructions for dane elec 4gb memory stick
just plug into any usb slot on your pc then go to ''my computer'' and double click into the removable drive. drag and drop or copy and paste
Mar 11, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-elec usb portable memory stick - right protect error
pu *** into you rown pc again and format it. when it is done formatting reboot your pc and let usb in while rebooting. when its done you can use it again but when used take it out with "safely remove hardware" option.
hope this helps otherwise they have a return and guaranty service at least
sorry for grammar but im not english
Jan 02, 2009 | Dane Elec DANE-ELEC DA-M4-04-ML2 Meizu 4G...
Can't place files on my Dane Elec Usb stick
Well maybe it's full... check.. Maybe it's "Protected" in some way... maybe it needs to be "Shared" in permissions.. otherwise maybe it has gone kaput... hope not.. GL
Jul 25, 2008 | Electronics - Others
Write protected memory card..sd card
There should be a little switch on your memory card reader, if it is facing down, your card is locked. Push it up and then you should be ready to go. :)
Jul 07, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
My 4gb dane elec doesn't let me ready boost, and it has nothing on it!
bonjours je vient de machetter une cle usb dane-elec 4GB l'ordie pas de pilote logiciel DISK2.0 je suis sur wista merci d'avance
Mar 21, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
96 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
woodzowl307
pankaj rautela
pankaj rautela
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
