Reset olevia remote
Medicom changed channel lineup how do I change my Olevia TV remote
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Posted on May 17, 2014
premtech
  • 934 Answers
SOURCE: Remote control codes
Juni,
You'll have to look it up by the remote you're using... Then by the brand of Tv you're trying to control.. try here..
http://www.remotecodelist.com/remotes/
Bill
Posted on Dec 27, 2007
  • 3 Answers
SOURCE: RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Posted on Mar 08, 2008
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Posted on Mar 29, 2008
SOURCE: olevia 232 hd tv remote codes
this code dd not work with my remote for the olevia 232v..
maybe i will just buy a new remote for $29.00 and be done with it...; > (
Posted on May 09, 2008
  • 362 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Posted on Feb 14, 2009
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Olevia lct tv can't do a channel auto scan
first check the batteries in the remote to make sure they are not low and then have the remote tested most repair shops do it free.
Mar 14, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 237V S11 Firmware
for all firmware updates you must go to this site http://www.olevia.com/en-us/Support/Firmware.aspx
and follow the directions...............(note you must have a blank usb flash drive)
Jun 20, 2009 | Syntax Olevia 537H Television
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Apr 12, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Apr 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 237 with satellite dish
I purchased a universal remote URC-R6 from Best Buy that someone else had said worked for them. With a little work, I have programmed it to take the place of both my remotes. Seems to be working fine!
Aug 23, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Program remote for olevia television
I have a olevia tv with olevia remote, I have to type in the number to change the channel. what do i need to do to fix the problem? So i can use the tv channel changer.
Dec 23, 2007 | Bose Cinemate Digital Home Theater System...
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
