Question about Pool & Spa
Waterco 4 in 1 test kit instructions
Need to see instruction video for waterco pool test kit .
Nikhil Gedam
  • 87 Answers
SOURCE: Need Instructions on Maintenance Kit
Please let me know what are the other parts you are trying to install.
Also, installing a maintenance kit is not a customer replaceable part.
Posted on Nov 03, 2008
  • 205 Answers
SOURCE: No instruction manual for Toro 59131 Dethatcher Kit
Go to toro.com and in the "search box" on the home page put in "owners manual" and then look for your model # on the next page. you should be able to print all or just the page you need,
If this works for you please leave a Fixya rating for me
good luck , Chuck
Posted on Mar 21, 2009
SOURCE: NEED INSTRUCTIONS TO GROW LOST THEM.
there is a link to the instruction manual on this page: http://www.discoverthis.com/smitcrystal.html
Posted on Apr 04, 2009
  • 670 Answers
SOURCE: I need instrucions for how to set up a model 108r intex pool pump
Best I could find. Includes drawings. Good luck. http://www.inyopools.com/guide_new_above_ground_pool.aspx
Posted on Jun 22, 2009
thepool
  • 78 Answers
SOURCE: help with pool filter
instructions are here http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on Apr 21, 2010
My waterco portapac was fitted 3 months ago. worked beautifully until 2 days ago. Now it is not heating. Any ideas? Thanks
it has a pressure switch that is a common failure pump waterco portapac Google Search the switch looks like this in most cases and is a gravy fix waterco portapac Google Search now you can bypass it FOR TESTING ONLY ! to see if it is indeed the culprit, it's around a $20 part and nice to have on hand Also check to see if the pump has a restriction, like a plugged impeller, debris might got into the pump and restricted flow, causing a low pressure situation ? Australian Spa Parts
Dec 30, 2014 | Waterco Pool & Spa
Pool stabilizer
Their are no test kits available for residential home owners. Wherev you can take your water sample to will be able to test for cyanaric acid(stabilizer). They will give you the value to add to the water. Follow the instructions on the stabilizer container to add the amount based on the water volume you have for your pool. Most recommend adding it into a stocking and hanking it from the ladder or inside the skimmer to allow for slow dissolving
Jun 28, 2013 | Arch Chemical HTH Pool 4 LB Stabilizer &...
I have a waterco titanium pool heater water is pouring out of drain holes in the bottom of unit.I have to keep filling up the pool every other day.what do u think is causing the water to puor out like...
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
Mar 09, 2013 | Waterco Baker Hydro 80K Btu Titanium...
I need installation instructions for a instamatik 55. Thank you!
l'eau entre par la gauche et ressort par la droite. Est-ce qu'elle est deja brancher??? moi, j'essaie de changer la temperature en pessant sur plus ou moin et ca ne bouge pas. est-ce que les tienne change???
Jun 26, 2011 | Waterco Baker Hydro 55K Btu Titanium...
How do I replace the sand in my waterco t400 pool pump. Is there a manual available
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Nov 01, 2010 | Pool & Spa
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
Pool & Spa Logo
71 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
