How do I get an RCA TV to respond to turn off CC. Remote and console controls all work but still have CC.
Menu display shows "off all the time" for CC display.
android1
  • 5 Answers
SOURCE: RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Posted on Nov 21, 2007
jay196969
  • 41 Answers
SOURCE: RCA RCA311B Remote Control
i also have the same remote and t.v. i found the codes on this website
http://support.rcaaccessories.com/doc/aud1744.xml?docid=810&Referring%20DocID%20List%20Index=4&navtypeid=6&pagetypeid=2&prevPageIndex=4&selectedmodel=RCR311B&selectedFamily=generic
Posted on Dec 17, 2007
eagle338
  • 4889 Answers
SOURCE: Sharp Aquos LCD TV 52"
Its in the TV Setup. The Cable box will output the Closed Captioning on Line 20 or 21 of the Picture - this is just at the top of the TV Picture where you can't see it. The TV Menu should have a choice of closed Captioning like CC1, Teletext, etc. and one of them should be selected. After exiting the menu, you should start seeing Closed Captioning
on the tv.
Posted on Apr 08, 2008
dauphine
  • 207 Answers
SOURCE: universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Posted on Apr 10, 2008
SOURCE: RCA Universal Remote Control #451--Closed Captioning Will Not Turn Off
I can't figure out how to turn the cc off either. I went to menu and then audio then captions and off but they still won't go off. The captions are only on when I am watching HD channels. Anyone know why?
Posted on Oct 11, 2008
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
I have a Sony TV and purchased a RCA remote control new from Walmart (as a replacement for a Sony remote control). The RCA worked fine for 2 months until I accidentally hit the wrong button. The little...
Sep 16, 2008 | Computers & Internet
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
I need to set up cc however I dont know how and i dont have my manuel what do i do
Check the tv remote control look for the button said CC get it on to CC1,2,3 one of these numbers will show close captioning,if the the show have captioning.Or tries go into the menu goto Captioning or Text functions turn on 1,2,3 will get the captioning functioning.
Jul 16, 2010 | RCA TruFlat 27F520T 27" TV
Need codes for LG tv from rca remote thank u.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV.
3. Press and release the TV button
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this works for you.
Jul 13, 2010 | RCA Universal Remote Control
Can't see closed caption
U have a CC button on ur remote?Press it multiple times in the display will get CC1,2,3.One these number will get u Captioning,if the show said captioning or have CC display before the tv show start.No,CC button on the remote,go to ur main menu go to captionning functions turn it on like CC1,2,3.Don't turn on text,u will get a big black box in the screen all the time.
Mar 22, 2010 | Televison & Video
VCR stuck on menu screen
Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
Mar 09, 2008 | RCA Universal Remote Control
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
