Question about Garden
I need 2 open the trans 2 look 4 dammage
It is a30inch murray select
  • Garden Master
  • 2,478 Answers
Do it.
Posted on May 17, 2014
I have a 1996 Murray tractor and the speed of the tractor gets slower the more it is run. Where should I start?
check belt that goes from motor to trans. check pulleys and the bearings in the pulleys for same belt.
Aug 24, 2014 | Murray Garden
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
I have to error code with my jeep grand Cherokee Laredo 1999 the code are 1491,1495,753,136
P1491 Rad Fan Control Relay Circuit An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays.P1495 Leak Detection Pump Solenoid Circuit An open or shorted condition detected in the Leak Detection Pump (LDP) solenoid circuit.P0753 (M) Trans 3-4 Shift Sol/Trans Relay Circuits An open or shorted condition detected in the overdrive solenoid control circuit or Trans Relay Circuit in JTEC RE transmissions. Was MIL code 45. P0753 (M) Trans 3-4 Shift Sol/Trans Relay Circuits An open or shorted condition detected in the transmission 2-4 shift solenoid circuit (4-speed auto. trans. only).P0136 (M) 1/2 O2 Sensor Heater Circuit Malfunction Oxygen sensor heater element malfunction.
Aside from getting into an accident and having your wiring harness severely damaged, the other likely suspect is your PCM. These codes are not related to each other and indicate a much larger problem.
Nov 02, 2013 | 1999 Jeep Grand Cherokee
How to put belt on Murray Select 40inch 13,5 HP
1 O drive pulley
2 O IDLE
3 O SPINDLE PULLEY 4 O SPINDLE PULLEY
Around 3 and 4, left side 2, round 1
Jun 17, 2013 | Garden
Can a 2008 4wd (4 x 4) GMC Envoy be flat towed? If so, what is the procedure? Will it register miles on the odometer?
any 4x4 should be trailered, as dammage to the trans or transfer can result, if you have to tow i recommend you remove the drive shafts
Sep 15, 2010 | 2008 GMC Envoy
I need to replace my half shaft (Drivers Side).
Remove the lock nut on the wheel, Big nut in the center,Get the tie rod loose and lower ball joint all out of the way. You have to pry the axel out of the trans, best done with a long flat bar, between the inner joint and the flatest part of the trans. Like you are popping it out. There is a circlip that holds the joint in like a spring. careful not to dammage the trans seal.
Sep 19, 2009 | 2003 Pontiac Grand Prix
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
