Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My handy is not communicating with my heater, but it is with all the other functions. Any thoughts ?
  • Dan Galasso
    Dan Galasso May 17, 2014
    Hi Alan Wallenstein, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Type of heater. Make and model
    Problem Solver:
  • 7 Answers
What type of heater do you have? Some heaters need to be setup into a remote mode. Possibly it was taken out of this mode or never set up. How do you have the heater connected to the system? Heater should not be connected to a relay. Instead should use pins #1 and 2 on the top bus bar of the control system connected to the fireman switch or remote control connection on the heaters circuit board. Send me some more info on these items and I'll better explain how to set it up
Posted on May 27, 2014
GE model gth16dberww top mount freezer. Freezer is iced over. Removed rear cover and coils are also iced over. Poured warm water into drain and water immediately exited to drip pan. not sure where to
Sounds like the defrost timer is not functioning, or a defrost element is burnt out.
#1. After an accumulative "run time", typically the timer will initiate a defrost cycle. At that point the defrost heaters are energized and the compressor is turned off for the duration of the cycle. The defrost time cycle varies from manufacturer to manufacturer and can be as low as 15 minutes to as much as a half hour. If it is defective, it could be stuck in the cooling position not initiating a defrost function.
#2. If the defrost heater element is burnt out, the timer functions normally and will cycle the defective heater on, but there will be no heat generated to defrost the ice.
#3. A more remote possibility is a defective "defrost termination thermostat" which is wired in series with the defrost element. If defective, it will keep the element from energizing on a call for defrost.
At any rate, unless you are extremely handy AND have access to a supplier of repair parts, it sounds like a service tech needs to be called.
Oct 17, 2014 | GE Refrigerators
Whats the problem if blender is gone in 1998 GMC Sonoma
Are the controls for opening the heat functioning? Opening the heater core and allowing fluid to pass through the core would be where I would look. For instance you could remove the outlet hose from the core and see if water is passing through. Thinking it might be a clogged heater core. How about the heat gauge on the dash? You said the hoses were hot so guess the engine is reaching proper temperature. If you have A/C can you get warm air when you use defrost? If so, the heater core is OK. Conclusion: My first thought is the heater controls are not working properly but if they are then my second thought is the core itself. Hope this helps you.
Jun 07, 2014 | 1998 Chevrolet S-10 Pickup
Aquapod doesnt sync with heater any more
what type the heater is communicating to aqualogic control is RAYPAK digital 2100 ? also go to outside where the aqualogic control is and look for diagnostic in control look for water temperature sensor connecedt to aqualogic and see what that say,
Jun 15, 2013 | Hayward Pool Products Aqua Pod
Remote control error code is C7 or CF, What does this mean?
Hi Bob, sorry for the problem.
Error codes are a starting point for diagnosing problems, and the same error on one machine can have different cause and solution than another machine.
Open following link for Rheem troubleshooting resources that will be handy to keep on file.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Generally C7 is remote cannot communicate with tankless unit.
Your remote is connected by wire back to the heater.
You can turn power off, remove remote wires from connection terminals on tankless, turn power on, check if tankless works correctly.
If tankless works, then problem is the remote control, or wiring, or parts inside tankless.
Chances are good, the wires are not the problem.
New remote costs $99, but that may not be the problem, so instead of guessing, you should call a service technician.
Steps above could restore functionality and water heater will produce hot water at default temperature.
Also read manual for advisories, troubleshooting error codes, and required maintenance.
For example water filter should be cleaned monthly and heat exchanger de-limed yearly.
Tankless are maintenance heavy, and parts and service combined with maintenance makes these units a risky investment compared with expected $1-8 monthly savings from owning gas tankless.
Reading the manual can save some expense, and the link above is a good resource for people wanting to hold down costs.
Repair most tankless problems yourself, same day, any brand for about $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Rheem Tankless Water Heater Main Remote...
Error code E000002-0000
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If nothing of these helps, send more specific description of problem.
Hope it helps
Jul 06, 2010 | Canon imageRUNNER 2200
How do i get an owners manual for a Handy Master kerosene heater (HM19)?
I get about 90% of my manuals from the manufacturers web site. Give that a try. You may have to do a bit of research, I do not recognize the Handy Master brand, it may be a relabel from another manufacturer.
Good Luck
Gilshultz
Dec 02, 2009 | Master Heaters Master B115DT 115,000BTU...
Control panel not working after "function lock" buttons pressed
MD,
Hit the up and down again and do away with the Function Lock.
Tom
Apr 23, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Iflo digistat+2RF remote control for combi boiler
there should be an overide button on reciever try checking if stat is still communicating with reciever when stat is turned up and down light should flash on reciever
Oct 23, 2008 | Lasko 5540 Ceramic Compact Heater
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
62 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
