Question about Zonet (ZSR0104UP) Router
Zonet ZSR0104CP port forwarding
I'm trying to setup this router so that traffic can get to my webserver. I've done it on Linksys routers with no problem, but they keep dying(disposable?!?). On the Zonet admin page, you're supposed to be able to click on NAT and select Virtual Server. However, that screen doesn't come up on mine. I'm wondering if I need to do a firmware upgrade, or if the instructions that I found on the net are just incorrect( don't know where the manual is at the moment). Anybody have any experience with this router? Thanks!
Nevermind. For some reason it took a while(like a day) for the settings to take effect(!?). Don't know why - the Linksys always took effect immediately. *sigh*
Posted on Jun 25, 2009
Connecting a Linksys WRT54GL. no internet connection detected
The ISP modem connects to the main LAN port on the router. The PC connects to any other port. Done. You should have internet via wire at this point.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
Laptop Can't Find New Cisco Linksys EA4500 N900 Router In Setup
Try this, your IPS Virgin, is a modem? remove AC from the ISP modem and remove battery(If it has one), remove AC power from the Linksys. Insert battery and plug in the virgin ISP modem, allow it to run the self test, may take a few mins. Plug in the Linksys, ( Is it secured with a SSID and security code?), wait for self test. turn on your computer boot normally. If that fails try this procedure: http://compnetworking.about.com/cs/windowsnetworkin1/ht/renewipaddrwxp.htm
Dec 02, 2012 | Linksys by Cisco Linksys Ea4500 Dualband...
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
Have a netbook how to install linksys router wrt120n
Are you trying to install Linksys router?
You don't need to run the CD.
You can do it manually.
Connect your netbook to the router and open the setup page of the router.
Change the settings manually and you are done.
See Linksys router setup
Oct 03, 2011 | Linksys WRT120N Router
Can't configure router for Domain name and DNS
dns= domain naming service or something alike...
you don't have normally to anything to your router other than allowing incoming traffic to port 80...once you do that, you should be all set..frrom your computer at home if you type your domain name, your pc actually goes to the internet clowd and accesses you new domain name based on the info gathered by dyndns...then comes back to the ip that your ISP assigned you and hits your webserver...
A couple things to consider;
keep an eye on the ip assigned to you by the ISP..if it changes by DHCP your webserver won't be seen by the outside..
on your side of the home network, assign a static ip address, don't use dhcp as well to avoid the same problem on the pc that you have the webserver. your router should allow you to allow traffic on port 80 to your webserver computer, which has the static IP...
if it does not, buy another one
Feb 07, 2009 | Buffalo Technology AirStation WBR2-G54S...
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from http://www.linksys.com and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
How do I set up my Linksys router?
Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
LinkSys Router Setup Video Tutorials Learn how to set up your Linksys Router.
Thomas installs a Linksys router to demonstrate what ease-of-use means.
I really hope this information is helpfull.
Aug 12, 2008 | Computers & Internet
I want to setup a wireless network with 3 deskops and atleast 2 laptot
Linksys has a slim Web server built into their routers and a nice little Web based configuration management interface. You can configure your router to pass or filter IP multicast. Most of the Linksys routers have a filter configuration page where you simply check to filter/pass multicast traffic. As for the VoIP/Teleplhony trafic, you should select one of the routers that allows Quality of Service (QoS) - only some routers support this. The QoS router may recognize the voice traffic automatically but at most you would have to specify the applicaation/ports to give priority to. Again, all is done easily via the Web based management utiility - no CLI needed.
Roger
Aug 04, 2008 | Computers & Internet
Zonet (ZSR0104UP) Router Logo
265 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
