Question about Onkyo Audio Players & Recorders
Why does my NR525 hdmi output flash magenta on my TV?
I have swapped cables, but the output flashes every second or so and the picture is a magenta/pink/purple colour? This happens for my Sony BD and my WD media player, but they both work fine if I plug them straight in to my Sony Bravia.
5 Suggested Answers
  • 3 Answers
SOURCE: Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Posted on Jan 27, 2008
SOURCE: Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Posted on Feb 08, 2008
gymhasafit
  • 31 Answers
SOURCE: no video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Posted on May 04, 2009
SOURCE: Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Posted on May 27, 2010
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Satellite Receiver to Yamaha Receiver
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
Mar 18, 2010 | DISH Network ViP 612
Feb 06, 2010 | Denon AVR-2805 Receiver
TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Aug 12, 2009 | Yamaha RX-V663 Receiver
When running video thru the amp, the pic flashes on and off
usually that is an issue of cabling and/or the monitor. The Marantz units are pretty darn stable. Check your setup to see if it is upconverting.
If you can, try a new HDMI cable to the TV. You could also try the second HDMI out, to see if there might be a problem with that particular output port. You can also try a different HDMI port on the TV.
Another thing to try is to directly connect your DVD player to the TV. If your cabling is all in walls, etc, you can get an HDMI coupler at a big box store for $15.00 or so. That will tell you if it is any of the cables, the DVD player, or the TV.
Jan 05, 2009 | Marantz SR7002 6.1 Channels Receiver
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
TV Flashed HDMI
check samsung web site for firmware upgrade, or use component cabling, which is HD also
Jul 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
24 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
