Question about LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
My external drive keeps spinning down or something and freezes up wahtever program is using it (FCP, Lightroom) I have it partitioned into a few discs. How can I keep it active?
  • cvanderl Jun 23, 2009
    Using on Mac OS X 10.5.7
  • 400 Answers
Change its format to Fat32 if on NTFS and there could be the OS fault so recommend that reinstall OS and better if Replace it with Windows 7 Faster and easier if not using one..Regards
Posted on Jun 23, 2009
How to cope with Laptop C partition low disk space error problem
Hi Belinda
Basically it is a good idea to use the "C" drive for the Operating System (Windows) and minimal 3rd party software.
Move all Movies, Music & Photo's to another drive. The "D" drive.
This can be internal or external depending on the computer.
An external 1 to 4 Terrabyte drive on the USB port is really useful actually... it is really mandatory these days to perform backups & keep the big files on. Like Movies & Music & Photos.
To give you long lasting capabilities into the future I would suggest something like this Dock Drive
http://eshop.macsales.com/shop/NewerTech/Voyager/Hard_Drive_Dock
You get to choose which drive to plug in and they can be stored securely (in tinfoil antistatic) when not in use.
The dock will allow you to keep a bootable emergency drive on one drive and a backup of all your movies on another and even a copy of all your music on another. This is my preferred method as it's future proof. if your computer gets broken or stolen then you still have a copy of everything. I prefer to use the 3.5 inch (larger) drive as they have faster access & backup capability. The 2.5" drives are great for portability & run on 5volts only so are not as fast. The dock can take either.
Hope this Helps
Nov 27, 2014 | Computers & Internet
External drive is seeing phantom partition
Small partitions from OEM's are common. These are used for recovery or special OEM functions and are usually protected from over writing. Generally only a low level non OEM format program (read generic here) will over write them. But , if you over write this partition, your IOMEGA external drive may not boot properly.
Jan 03, 2014 | Computers & Internet
My iomega ex hd wanted to reformat. it started but i stopped it before thew end. did I loose all the info on it
Unfortunately, you probably did. However, you do have a few options to fix it.
Option 1: Recover deleted files/partitions
Download the active@ partition recovery utility and try running that. I'm not 100% sure how this program works, so you might need to look around the site for some tutorials or something to get it working, but it seems like a pretty good solution.
Option 2: Rebuild the partition.
In order to do this you need to know what file system was originally on the drive. It will most likely be NTFS or FAT32. The best way to do it is to get a linux live cd like the System Rescue CD. Download the .iso file and burn it to a disk, then boot your computer from the disk. Keep hitting enter until you get a command prompt (should say root@sysresccd$). At that point plug in your external drive and wait a minute or two, then type "fdisk -l" (NOTE: That's an "ell", not an "eye". Also, don't type the quotes). You should see some entry on there for /dev/sdb, but it probably won't have any partitions at the moment, which is fine. However, write down the size of your Type "fdisk /dev/sdb" to enter the disk formatting screen. Now type the following:
n (to create new partition)
p (for primary partition)
1 (for partition number)
default for First cylinder
7 (for NTFS partition)
w (to write changes)
Next, type "ntfs-3g /dev/sdb1 /mnt/backup" and "ntfs-3g /dev/sda1 /mnt/windows". This will mount your external drive and internal drive to /mnt/backup and /mnt/windows respectively. Type "cd /mnt/windows" then "mkdir backup" to create another folder. Now type "rsync -av --progress /mnt/backup backup/" to copy everything available in your external drive to your internal drive. Hopefully you can get your stuff back, best of luck!
Tj
Aug 22, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
I have an external hard drive that I want to use as a PVR , my satellate Tv provider says that it can not be any more than 1TB. the drive I have is 1.5TB, can I partition the drive and make it look like it...
there are several programs suited for this task, just google search for a partitioning program and follow the wizard steps in the program to re-format a partition to the appropriate size and format.
Jul 27, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
How do i partion my segate hard disk, it is 5oo GB
In order to partition a drive, you must use the partition manager. There is a command-line version of this application that is more consistent between the different Windows OS's so I'll instruct you in that.
First we need to be sure we are partitioning the correct drive. Open up My Computer and write down what drive letter your seagate external drive is (i.e. G).
Now let's start up disk partition manager. click on the Start button, and then click on "Run" type in "diskpart" (without the quotation marks) and press enter. This will open up a command prompt window with the heading "Microsoft DiskPart...".
Type in the following command: "list disk".
This will bring up a list of all of your disks currently recognized by the computer. Be sure the drive letter you wrote down earlier is on this list, also write down the drive number corresponding to your seagate external at this time. now go ahead and select this volume by typing "volume __" where __ corresponds to the drive letter of your seagate drive.
Now that we have everything set up we will create the partition.
type "create partition [size=_]" where _ is the size of the partition you want to add, in megabytes (MB).
If you encounter any trouble or want something more than a simple partition see the full instruction to use the diskpart utility here:
http://technet.microsoft.com/en-us/library/cc766465%28WS.10%29.aspx
Best of luck! and please rate my response
Jul 13, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows XP freezes up when trying to reinstall on my Dell
You need to copy the restore partitions to a cd for back up.the wipe the drive using drivescrubber.also have a start up disc for back up.wiping the drive from back to front should keep the basic files for dos.its easy and there is a free version.
Sep 20, 2009 | Dell Dimension 3000® Pentium® 4...
Maxtor drive partition
I'm not sure how you do it with out a program. If you google something like "Partition Editor Program", that may be the best thing for you.
Jan 26, 2009 | Maxtor OneTouch II external hard drive...
Maxtor 1Touch4 won't connect
FIXYA! Hey, found out my maxtor issue...pretty much by accident though, with a little pinch of desperation. I powered down my MacBook, disconnected the drives (2) from their firewire and power and waited for about, oh, I dunno....30-40 seconds. Upon stubborn study of the power supply, something told me to just switch one adapter for the other!
So...I did it. Once plugged back in to my power strip, both LED's lit up and stayed continuous. Then, I just reconnected their firewire ports and, voila!...I was back online. Hate to think all that stress was just a matter of swapping power cords...but...here I am.
Hope that helps someone else.
Dave
Jul 07, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB Logo
524 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
