Question about Moyer Diebel Dishwashers
Dishwasher not shutting off when you open door water spillsout
3 Suggested Answers
skrbin
  • 121 Answers
SOURCE: Water keeps running
check electro-valve must be broken,you must
change it.
Posted on Feb 16, 2009
  • 4088 Answers
SOURCE: Water enters dishwasher, soap door opens but soap
That's a normal path for the soap. It sounds like the water just sits in the bottom without being pumped through the spray arms. Does the pump motor run? Pop the door open in the middle of the washing cycle--you should see hot water dripping from everything and the soap picked up and circulated with the water. If this machine has seen a lot of use, the intake screen under the lower spray arm may be plugged and is accessed by removing the spray arm and working your way down to the bottom of the deck. Might be a problem for a service technician to take care of.
Posted on Jul 19, 2009
Why does it stop running after two mins and has an error code of OE?
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 13, 2016 | LG LDF6810ST Stainless Steel Built-in...
Frigidaire dishwasher stops in mid cycle
two things to look at : water level sensor ? seems I once had a machine that the water inlet valve never totally shut off and it overfilled basin this shut machine off on a spill sensor fault but took several minutes to do this , Also the door closed switch , seems they do get finicky as time goes on and even thought door stays closed the movement of machine opens the door switch up (not the door) this also takes several minutes to occur
Sep 02, 2015 | Frigidaire Dishwashers
The dishwasher switches on and drains the water out while the door is open coul you please help
There is usually and interlock switch for the door latch that shuts down the dishwasher if the door is opened. It sounds like the switch is stuck in the closed (thinks the door is closed) position. That switch may need replaced.
Jun 02, 2015 | Tecnik Dishwashers
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
Dishwasher over flowed this morning. I hit the cancel/drain button and the water drained but kept coming in from the inlet valve. Had to shut the water supply off to the dishwasher.
Sound like the possibilty of the inlet valve regardless once the door is opened shut down power to the unit unless you have mulitiple failures going on at the sametime.
Nov 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Pump will not shut off even with door open
Hi, There is a float under the dishwasher to protect from flooding... If there is a leak and there is water under the dishwasher in the pan then the float switch will turn on the drain pump...
first I could remove the toe panel check in the pan for water... if no water still check the float it maybe stuck up (soap can get under the float and hold it up)
remove water and make sure float in down... if not you may need a new float switch...
Sep 28, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Water coming out bottom of door on wash cycle.
you have a bad fill valve. unplug the unit from the wall or turn breaker off and tell me if the water still comes in if the answer is yes you have a bad fill valve.
Jun 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher sounds like its working but when i open it nothing
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
May 30, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Water keeps running
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
Feb 16, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Dishwashers Logo
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
