Question about Hobart Airforce 250ci Plasma Cutter 12 Amps
It top cutting and the cup light flashes replaced all in the cup ..still flashes
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
Senseo will not turn on or heat water
No need to see what is in the manual.
But what I type here, you also have to read.
The manual gives pictures. I'm not.
Remove the transparent back of the machine and fill it with water. a few centimetres under the top, you fine the line for max fill.
Then replace the transparent back on the machine. Then plug in the power cord and press the power on button. (once is enough) a light comes on and flashes, when the mains plug has power.
Then wait till the light stops flashing. In the mean time put a coffee pad in the top and close the top all as described in the manual.
Place one or two cups under the nozzles and press the button with the one or two cups. (two cups gives twice as much water, so place two cups.
That is all.
Jul 21, 2014 | Philips Senseo HD-7810 Coffee Maker
Power on kuerig but no flashing cup lights
Did you flip the top up that holds the k-cup and then back down again?
Nov 07, 2012 | Keurig Elite B40 Coffee Maker
Add water, heating, and small cup light flashing
Handle not engaged all of the way. Rest and press firmly in place,
Mar 24, 2012 | Keurig Elite B40 Coffee Maker
Small cup, add water, heating lights keep flashing after brew
I had this problem too.
I just pressed the small brew button; it pulled some water from the reservoir and heated it but nothing came out. Then I opened and closed the top cop thing and both the cup sizes were flashing and it worked like normal again.
Oct 16, 2011 | Keurig Elite B40 Coffee Maker
PURCHASED B44 TODAY. CAN'T DO SET UP. PLUG IN, POWER UP, BOTH CUP AND MUG LIGHTS LIGHT UP (NOT FLASH) HEAT LIGHT FLASHES GOES OFF-TOP OF UNIT WARM. WATER DOES NOT TRANSFER TO UNIT. REALLY LOOKED FORWARD TO...
We just had the same problem with ours, and solved it by lifting up the grey handle to open the coffee maker, and closing it again. Not sure what the issue was, but this got the single cup light flashing the way the instructions said it should.
Dec 24, 2010 | Keurig Elite B40 Coffee Maker
I have a keurig b30 and has been working great but now it will not recognize any of my cups so the flashing blue light will not come on to start brewing? none of them are clear and have all worked in the...
I haven't solved the problem, but I continue to disassemble my K30. Most likely points of failure for the blue start light not coming on appear to be a sensor to detect the cup is in place (two small holes on the left/right front edge of the cup holder) or a sensor in the resovoir lid where the blue pin presses on a pressure switch. I did find that the red wire to this switch gets caught in the lid hinge and may be damaged. I will post more if I finally discover the root cause but may just go to Bed Bath & Beyond and buy the resovoir model with a 2 year warranty. Lesson learned. Cheap switches and mechanical devices.
Nov 06, 2010 | Keurig B30 Mini Coffee Maker
Ice machine does not make ice
No guide that I know of .
Open the freezer door and see if the laser light on the right side , flashes twice , then pause , repeatedly . Close the flap on the left side , and the laser should stop flashing . If this is what occures , then the optics ( cut off of the icemaker ) are ok . If you open the freezer and no laser on the right , check the position of the "rake" inside the icemaker . Close the freezer door for about 1 min , and then recheck the position of the rake . If it hasn't moved , then the icemaker is bad .
If the light flashes 2 times then pauses , pour about 2/3 cup of water into the icemaker , and check later , to see if the ice maker has dumped the cubes . If did not dump , replace the icemaker . If did dump , and did not fill with water , then the water valve behind the refrig is bad . Also check the black fill tube above the ice maker fill cup , to see if it is iced up , keeping the water from going into the fill cup . If it is frozen , then replace the water valve , due to seeping ( not closing completely ) , causing the slight drip , to freeze inside the tube .
This is the only guide I know of and it's called an experience guide .
Sep 27, 2009 | KitchenAid KSRG25FK Side by Side...
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
It won't print
Out of toner. Replace the Toner Cartridge.
Dec 19, 2008 | HP LaserJet 1320 Printer
Hobart Airforce 250ci Plasma Cutter 12 Amps Logo
109 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
