Maytag Epic has a damaged wire harness connection to the touchpad assembly.
Somehow the gray ribbon wire harness came loose during a wash cycle and two of the wires split from the ribbon split. Can I just fix the split (rewire them back together) or do I need to get a new harness? And if it's possible to fix the damaged ribbon, how would I go about doing that?
  • 3 more comments
  • jparker May 17, 2014
    I'm not troubleshooting really... I already know what's wrong with my washer. When I took the top off my washer, the wire harness that connects to the control panel has two severed wires. It's this part:
    Ooops... guess I pressed enter too many times. It's this part:
    Physical Specifications - GREY CABLE: UL AWM Style 2651
  • 1,140 Answers
To prevent any other new electrical problems, it would be better to buy a new ribbon cable.
Posted on May 29, 2014
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
vest6
  • 196 Answers
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Posted on Jan 13, 2008
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
  • 30 Answers
SOURCE: maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Posted on Jun 02, 2009
Flases f 21 code worked fine untill i put new front board in and i cleaned out lines and hose still giving f 21
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad.
Apr 01, 2011 | Maytag EPIC MFW9600S
Maytag Epic Z MHWZ600TB01 Only Runs In Spin Mode. My Maytag front-loader will only run spin cycles. When I press the "start" button on any wash cycle, the power to the unit turns off. I used to...
Hi!!
Click on the following link for a diag. of the control panel. to get access to the back of the Control Board http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0901032-00003.png
check that wiring harness (#8) connections to the Electronic Control Board are tight and the wiring is not broken, burned or damaged. Disconnect the Unit and feel the wire harness (#8) for any small bumps or deformities, repair as needed.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 21, 2011 | Maytag MHWZ600TB Front Load Washer
What does a code f22 mean on my front load washer 9400
HI. This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Wich will be the actual CCU, if the wiring harness is ok, and connected properly)
Dec 30, 2009 | Whirlpool GHW9400SU Front Load Stacked...
The washing machine is flashing f21; we have checked the drains; front and back. The pumps are running fine. WHat could be the problem?
Replace failed component.(Which will be the actual CCU, if the wiriness harness is ok, and the touch pad is responding and connected properly)
Dec 21, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore he2 plus washing machine that keeps giving a code of f-21 on the final rinse cycle. i cant seem to figure out why that happens. sometimes it works, sometimes not. what could be causing...
2. Unplug washer or disconnect power. Gain access to the touchpad/led and CCU assembly.
Replace failed component.(which will be the CCU, if the harness is connected without any faults or worn connections present)
Nov 25, 2009 | Kenmore Washing Machines
Had f22 error - can't unlock door; tried CANCEL, tried RINSE/SPIN, tried UNLOCK, unplugged - door won't unlock
Replace failed component.(Which will be the actual CCU, if the wiring harness is ok, and connected properly)
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Sep 18, 2009 | Washing Machines
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
