Question about True Refrigerators
Ranco k series
I got a 2nd hand Haier mini fridge (HSE02WNAWW) to make cheese. Higher temp goes to 44F... and I need something between 50-60F. I opened the knob temp control box inside the fridge and saw the thermostat is a Ramco (not sure what model because it has printed K50, K52, K60, etc, so it one of the K series). I saw is has a little silver piece of tape covering 2 screws. The head of one is just above the surface as normal and the other is inside but there is a little hole so you can reach it with a screwdriver. My question is what of these 2 screws should I tight/loose to increase/get the temperature I need (50-60F)? I would really appreciate any light about it. You can reply to jaimef69@yahoo.com
    Novelist:
    Scholar:
  • 187 Answers
You need to take that control to a refrigeration supply house and get the proper control replacement. Those are factory set. One is differential and the other is set for temp. The adjustments in the field just don't stay put and will fail after messing with them. Ranco has a book that the supply house has that will give you what you need and the part is generally on the shelf. Hope this helps and good luck.
Posted on Oct 18, 2014
3 Suggested Answers
  • 1462 Answers
SOURCE: How do I remove cover from fridge temperature control panel?
lever off the thermostat knob and you will often find fixing screws behind. also, fixing screws are often hidden behind little blanking plugs which lever out to expose the screw head
Posted on Jul 21, 2008
  • 216 Answers
SOURCE: I have a True GDM-10
Eric,
Thank you for choosing FixYa. I wanted to ask quickly, why are you using a Ranco temperature controller? According to the manual for this refridgerator (available here even though it doesn't have the model listed, this is what I got every time I searched for this model, so I'm assuming it's the same) on page 20, there is a procedure for altering the internal temperature.
You will need a philips screwdriver, a 5/64" or 2mm allen wrench, and a T-7 torx wrench (all available at home depot, etc). You'll need to alter the temperature by a +20 on the low end, and +33 on the high end. These are referred to cut out and cut in temperatures, respectively. Follow the instructions on the manual to remove the temperature control. Each quarter turn increases the temperature by 2 degrees, to to increase your cut out temperature (the low end) to 50 degrees, you'll need to turn the allen screw clockwise 10/4 turns, or 5 full revolutions. Likewise for the cut in temperature (the high end), turn the T-7 torx screw 6 full revolutions clockwise, followed by a quarter turn (to increase to 67). If you want it up to 68, give it another 1/8 turn.
You can fine tune the temperature (with a little bit of effort and time) by replacing the temperature module then using a digital thermometer to measure the temperature. If it's outside the bounds of your needs, take the temperature control back out and tweak the controls a bit. Clockwise is warmer, anti-clockwise is colder.
I don't know if this actually solves your problem or is impossible for you, but I wanted to let you know in case you weren't aware that this model has a built-in functionality for altering the temperature. The issue you're running into is that constant cycling of the compressor without allowing it to defrost every now and then is very harmful to the system and can end up burning out your compressor, leaving you with very costly repairs.
Also take a look at this document. It is a technical service document for GDM models, and may contain some very good information. It sounds like you are fairly mechanically inclined, so I don't believe that you should have any trouble following the instructions.
Hopefully I could help, let me know if there's anything I didn't answer or anything else I can tell you!
Tj
Posted on Jul 26, 2011
How can I reduce my fridge temerature on my HRF370SS FRIDGE FREEZER, IT KEEP GOING HIGHER 9- 14
If this is tight against the back wall and even side, pull it out some so it can breath... When a fridge is tight against the wall it can't breath with Air and works harder hench a colder temp.... Try pulling it out.. UNplug for 10 mins.. Lower the temp dial.. Plug back in. Also if you have pets make sure not PST hair is clogged underneath the unit..
Sep 03, 2016 | Haier Refrigerators
Ranco k series thermostat
This thermostat is no longer available so be careful. Not knowing the workings though why not the direct approach. Adjust one screw in one direction (my guess is ccw) and see what temp changes. I would think the two screws are for high and low limits. If you cant get it higher (with knob at max) try the other direction first and then the other screw.... good luck.
May 16, 2014 | True Refrigerators
The cheese drawer keeps sliding open on its own
Adjust both front leveling legs so the fridge is slightly higher...not level.
Jan 05, 2014 | GE Refrigerators
Freezer cold, refrigerator warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 10, 2009 | Refrigerators
Which wires go wear when installing a new thermostat in my mini fridge?
In a mini fridge there are only two wires to the thermostat. I really does not matter which wire goes were because all it does is turn it off and on. Sea Breeze
Aug 26, 2009 | Haier HSA04WNC Compact Refrigerator
I have a mini fridge at school, a small Haier. My fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Haier Refrigerators
Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Sep 19, 2007 | Haier HNSE05 Refrigerator With Ice Box
Refrigerators Logo
74 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
