Question about Epson Stylus Pro 7880 InkJet Printer
Why is Epson Pro 7880 printing double image while in bidirectional
A Tech we hired changed the carriage motor. Before he arrived the printer was printing fine in bidirectional setting on the rip software. The next print after he finished and left on his way, we started getting a off alignment from the second pass. The tech claims it was the rip software. Funny, we hooked it up to another model and it printed fine. After he came back and did several tests from his service laptop and auto alignment on the printer, he still claims it was the rip software that worked fine before he serviced the printer. After upgrading the new software $500 later. We tried bidirectional again with obviously the same result. If he did nothing wrong, then I think it was a flawed part. If I can't solve the problem, I would prefer to just by another printer and write off the $495 for the service call. At least I will have the latest rip software and a new printer. Has anyone ever experienced this?
  • Epson Master
  • 783 Answers
That sounds like your wiper blade that cleans the drum between prints is showing some wear and not cleaning properly.
Running a cleaning cycle may help, but it is likely that wiper blade needs to be replaced. Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Posted on May 30, 2014
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Posted on Oct 25, 2007
SOURCE: Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Posted on Oct 28, 2007
SOURCE: Epson rx 500 "service required"
Press on off, load expulsion, byw,color and stop all at the same time, wait until it is on. then press color and then shut down.
Posted on Jun 25, 2008
  • 68 Answers
SOURCE: Epson RX500 printing problems
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson Stylus Pro 9880 Does Not Print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
The error code 0040 appears on my epson 7880. How can I solve it? Help me please!
You probably need a maintenance kit. It consists of new ink waste padsicon1.png, a purge unit, and some other little parts. Contact Epson support
Jul 30, 2015 | Epson Stylus Pro 7880 InkJet Printer
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Getting message error 0001000C on Epson Stylus Pro 9800 right after is done printing. The next print after message (after i turn off and on the printer) appears with double image on some areas.
its a carriage home position sensor error u have to clean the sensor and the stip guide which has been attached on carriage... its due to dust on sensor.
Oct 17, 2013 | Epson Stylus Pro 9800 InkJet Printer
Epson stylus pro 7880
maybe there is a problem in the chips of the cartridges (made in china :) ) or search for reset instructions ( if there is) somewhere in internet .
Good luck
Jul 24, 2012 | Epson Stylus Pro 7880 InkJet Printer
The error (ERVECE CALL ERROR 00020003) pops up just after I turn on the printer
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Nov 18, 2010 | Epson Stylus Pro 7880 InkJet Printer
What does error code 1000060 for the epson 7880 mean?
1. Measure the resistance value of the CR Motor. (5.8Ω)
If the CR Motor is found in short mode, replace the C472MAIN Board at the same time.
2. By visual inspection, check the T Fence for any defect, such as damage or soiling, which can cause faulty reading by the sensor.
3. By visual inspection, check the harness of the CR Motor for any problem causing a short circuit to the frame.
Dec 22, 2009 | Epson Stylus Pro 7880 InkJet Printer
How can i print faster from epson printer lq-300?
I recal a dipswitch story from long ago
Manual here:
http://www.retrevo.com/support/Epson-LQ-300-Printers-manual/id/259dj882/t/2/
Or try Epson itself.
It thin you can only switch from unidirectionalal to bidirectional
(last printing on cariage return also, doubling speed). If she is not already in this mode.
Apr 14, 2009 | Epson LQ 300+ Matrix Printer
Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Nov 05, 2007 | Epson LX-300 Matrix Printer
Epson Stylus Pro 7880 InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
