I have a dometic rv rooftop ac unit with a remote control thermostat. I lost the remote control. where can I find another remote control.
jbjaxiis
  • 95 Answers
SOURCE: Dometic Rooftop RV Air Conditioner
Possible bad capasitor, or seized motor
Posted on Jun 25, 2008
22yooper
  • 828 Answers
SOURCE: Circuit Breaker and Dometic Rooftop RV Air
Since your RV A/C works O.K. when plugged in to the land line and the trip happens when you run it on your generator the problem may be related to the generator output. It is possible that the power being supplied by the generator is not handling the surge when the A/C starts. Starting Amperage on start up is about 5 times the running Amperage for about 3 seconds until the compressor comes up to its rated speed.
Posted on Jul 24, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
  • 127 Answers
SOURCE: Compressor doesnt come on in a dometic duotherm
If this is a wall thermostat controlled unit, then check to make sure that you have power coming from the yellow wire on the thermostat when it is placed in the Cool/Auto High mode. If you do not have power at the yellow wire, then you have a bad thermostat. If you do have power, then remove the control unit from the inside of the AC and see if you have power at the Y terminal there. If so, when you turn the thermostat to cool, can you hear a relay clicking in the box? If not, then you have a bad control box. If the relay is clicking, you need to check the power at the compressor relay on the board. It has a black wire to one side and a purple (or blue) wire on the outgoing side. Check to see if you have 120V on the blue wire when the tstat is set to High/Cool. If not, then you need to bypass the freeze switch to make sure that is not the problem. If you do, then you need to go upstairs and check the start capacitor for OK. It is located in the side compartment of the upper unit, it has a small black relay on the top called a PTCR. These often burn out and will cause the compressor not to work. If that is fine, then you go to the top of the compressor to the thermal overload switch. See if you have power at both sides, if so, then you have a bad compressor. If not, then the overload switch is open and not allowing power to the compressor.
Posted on Jul 04, 2009
  • 332 Answers
SOURCE: RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Posted on Mar 06, 2010
Where can I purchase Dometic remote controller p n ir0101
Contact, American RV company at (626) 513-4777 they can help you out.
Jun 26, 2014 | Dometic Rooftop RV Air Conditioner
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Is this a thermostat problem or system failure?
it sounds like no communication from stat to board. cable connections
Jun 03, 2014 | Dometic Rooftop RV Air Conditioner
AC Wont stop running.
a defective thermostat thats all
Jun 02, 2013 | Dometic Rooftop RV Air Conditioner
Replacing the remote control for rv ac/furnace with standard thermostat
You are aware that the ceiling assy (control box) will most likely need to be replaced as well, to work in conjunction with new thermostat. If you contact dometic ( www.dometicusa) and give them your model number off bottom of roof unit and what thermostat you are trying to install, they will advise what is required.
Oct 17, 2011 | Dometic Rooftop RV Air Conditioner
Thermostat wiring for second ac unit
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
