Question about Korg Music
My Korg I5S keyboard cracks and pops in a terrible way. I suppose it's a defective condensor, but which one ........?
My korg micro-x synthesizer gets hot at the ac power input on the keyboard
hot connections indicate a short or bad connection ( like an arc welder )
loose wires or solder dry joint or broken wires creating a high resistance and heat in this area
Aug 06, 2016 | Korg Music
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
Some keys wont work
Your keyboard has a factory defect. Return it to the store or manufacturer and let them give you a new one.
If you waited to long and your warranty has expired take it to a repair shop. There is nothing else you can do...
Jun 13, 2014 | Korg Pa50 Professional Arranger Keyboard...
Hello everyone. The dial on my microkorgXL which changes the operations of the knobs does not work, is it possible to fix this? Without it I can't change anything or use the on-screen editor. I haven't...
Sounds like a bad rotary encoder (the part that the "dial" is attached to"). If the circuit board or solder is not cracked in that area then that is likely the problem. You could find the part at mouser.com (about $1) and would need desolder the bad encoder and solder the new one in place or get the whole PCBA(printed circuit board assembly) from Korg.
Aug 01, 2013 | Korg Micro Microkorg Xl Synthesizer...
Korg TR88 splitting the keyboard.
Read the manual if you've got it. If not get in touch with Korg.com and they should be able to tell you and you might get a manual download.
Good Luck
Aug 23, 2009 | Music
Music Logo
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
