Question about Electric Lawn Mower
Why won't my Earthwise electric mower that is fully charged start?
I mowed the front yard couple of days ago. Plugged in the mower to charge it. When I attempt to turn the mower on, I see three green lights, which should indicate a charge but there is no evidence that I've even tried to start it. The battery is just one year old.
bbreton
  • 437 Answers
SOURCE: where can I buy a bag for this mower
Go to www.precisionope.com and order one.
Good day.
Posted on Oct 10, 2009
  • 5 Answers
SOURCE: Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Posted on Mar 02, 2010
walesarumi
  • 6993 Answers
SOURCE: how to install new battery in earthwise 60020
Locate the battery on your lawn mower. It will be under the seat or under the hood.
Remove the old battery by using the correct socket or wrench to remove the nuts attaching each cable to each terminal.
Examine the battery for any restraining hardware and if present, remove using a wrench or a screwdriver.
Carefully lift the old battery out of the mower. Using a wire brush and a solution of water and baking soda, clean off the cable ends.
Lower the new battery into place and attach the black cable to the black, or negative terminal, and the red cable to the red, or positive terminal. Reattach any restraint system.
Good luck.
Posted on Apr 17, 2011
Asbestos 56
  • 191 Answers
SOURCE: electric mower will quit after
I don't know what model or brand this is but once you make sure you have power at the end of the cord (bring something else to plug in to test it.) My next thought would be the switch. This seems to be the first to go on some of these. Look at the housing and see if it is cracked or distorted. Post brand and model # also.
Posted on Jun 16, 2011
  • 721 Answers
SOURCE: TORO 20074A Starter not working.
OK seems to me you have a connection problem. This doesn't always mean that a connection where two wires plug together is bad. It could be a problem as simple as a mouse chewing thru a wire.
Take your time and check the wire or wires that go from your battery down to the starter.You may very quickly find your problem. A bad contact, a broken wire, a disconnected wire, or that bad little mouse, which will lead you to the purchase of a mouse trap before he causes you any additional headaches. GOOD LUCK.
Posted on Jul 05, 2011
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
May 21, 2015 | Electric Earthwise Corded Lawn Mower...
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
Tip
What's the hurry
What's this marketing ploy now days about cutting your lawn mowing time in half. I can understand that if u have a bunch of lawns to mow. Beings i only have one, I'm really not a big hurry. Take a look at your yard, do some thinking, and don't over spend. I only want to have to sharpen 2 blades not 3 or 4, and the less drive belts the better. U get your exercise with a walk behind, and get the grass cut too. Last time I was mower shopping, one salesman tried to sell me a 6,900.00 lawn mower. He said it would cut my mowing time in half. I said I'm not buying a mowing that's worth more than my pickup, and for 6,900.00 I could pay someone to mow my yard, and cut my mowing time down to zero.
ballping
on Jul 29, 2010 | Garden
I have a riding yard machine mower. Had trouble starting without jumping the battery. Bought a new battery & it started right up. Mowed the front & side of the yard & shut it off to open my...
Now you are describing 2 different problems... If you have nothing I doubt the battery is dead but would check for a safety switch problem. If it clicks or turns over slowly then we need to be looking at a bad connection or other issues... Please describe your problem better to let us help you solve it
Nov 13, 2013 | Yard Machines 155 Torque Briggs Stratton...
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Electric lawnmower battery won't hold a charge
charger for same does not show any lights..so should i assume the charger is not working?
Apr 28, 2012 | Electric Lawn Mower
My mower will not keep a charge very long. It use to keep a charge long enough to mow my front yard and back yard. Now I can hardly keep a charge long enough to mow half the front yard. It is 3 years...
Is this a battery powered mower?
If so, it sounds like the battery is dying. Batteries do have to be replaced, but 3 years seems like a short life. Ask your dealer before buying another.
Gary
Jul 05, 2011 | Ultra Garden
Electric Lawn Mower Logo
70 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
