Question about Plumbing
Manuel for MasterCool II HC63B - Plumbing
Mastercool accu-charge 2 scale
Are the terminals where battey connects clean if not they wont make the connection
Jun 01, 2016 | Mastercool MSC98210A AccuCharge II...
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
I have a MasterCool II MC63/64B and the thermostat has gone out. Since MasterCool is out of business, what model/brand would I replace it with.
If you are just running the evaporative cooler any single stage thermostat will suffice. You can buy them at OSH, Home Depot or Lowe's and probably Ace Hardware.
Aug 03, 2011 | Mastercool 67680 Evaporative Cooler Air...
How do i operate it?
Go to the Mastercool web site:
http://www.mastercool.com/pages/vacuum_pumps.html
Pick out your model number and then click on "instructions" to download a manual. The most important thing is to change the oil frequently. This unit is used in HVAC to draw a vacuum on an evacuated AC system after repairs were made to insure it is free of any condensables.
Aug 01, 2010 | Mastercool 15 Cfm Deep Vacuum Pump 90059
Need to know the difference between a master cool and a ultra kool
They are pretty must the same design, the Mastercool was made with heavier metal. But Mastercool are no longer being made,,,, so I guess if it's a new one you are looking for,,, Ultra Cool it will be.
Good Luck,
Paul
Mar 25, 2010 | Mastercool 67680 Evaporative Cooler Air...
Mastercool pump runs when themostat is off.
Check the compressor relay (in the outside unit) Most likely it's stuck.
Sep 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
I have a Mastercool II airconditioner, which is approximately 5 - 7 yrs old. Water has been overflowig from the unit. I believe the float probably needs to be replaced. I have no experience working with...
What you have is an evaporative cooler, it should be serviced every year, but most people can't afford that so they let it go or do it themselves. I don't know if you have ever worked on a toilet before , but your cooler has a float very similar to one in a toilet. More times than not you just need to adjust the float by bending the arm ever so slightly until the water shuts off on it's own. You don't want to bend it too far, it won't get enough water. If this doesn't do the trick you need to get an evaporative cooler float from your local hardware store, they can best tell you how to change it because you will have it visually in hand. Good luck
Jul 13, 2009 | Mastercool 67680 Evaporative Cooler Air...
Noise on mastercool
had the same symptoms and found that tightening the squirrel cage set screws eliminated the noise.
May 23, 2008 | Mastercool 67680 Evaporative Cooler Air...
Plumbing Logo
57 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
