Question about Chamberlain 950CB Remote Control
How do i fix garage door that wont open or close?
My son opened door manually during a power outage. now i can hear the chain moving but door doesn't open or close.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
You have to make sure the trolley on the drive engages with the catch on the door. You may have to lift the door to the point it will engage while you are running the trolley in the close mode. Check that the trolley latch is open and ready to engage the catch. There is usually a rope to pull on to do this.
Posted on Jul 27, 2014
5 Suggested Answers
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Posted on Apr 26, 2009
  • 10865 Answers
SOURCE: i have a chamberlain 950-315cb
Here is the website which will provide you with all of the info you need on the chamberlain remote and door openers
http://www.liftmaster.com/consumerweb
Posted on May 19, 2009
  • 244 Answers
SOURCE: changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
Posted on Dec 29, 2009
mindreader
  • 578 Answers
SOURCE: garage door opener won't close, light on unit flashes
Easy problem - and easy (temp) solution.
The safety pet sensors are blocked or broken
Press the button in the garage and hold it until the door is completely closed.....this over rides the safety sensor at the base of the garage door.
You cannot over ride the sensor with the wireless remote.
Check to be sure that the sensors are pointing at one another.
If they are, check the wires.
If good, the sensors have gone bad. Order replacements.
Posted on Mar 22, 2010
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Door wont close
The gear wheel powering the chain is stripped. The cogs are usually plastic and not uncommon for them to wear or break off. Replaceable item from manufacturer.
Nov 17, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
Overhead door opener 555 with manual release won't lockup chain
Sometimes if the clip is not reset then it wont catch the chain mechanism again to open or close the door. If you havent already reset the pull cord clip then that would be my guess. Try closing the garage door reset the clip with the rope attached, push it up til it clicks. and hit the garage door opener button. the rope and clip should move along the track until it hits the arm bracket where the garage door attaches to the chain mechanism.
If that does not do the trick then the clip has some screws on either side of the plastic casing and may need to be loosened and readjusted to match up with the garage door arm bracket and then locked back into place. That should do the trick if all esle fails, you may have to call the door company to come and correct the problem. Hope it works out!
May 28, 2012 | Home Security
I just had a power outage. My garage door was open during the whole afternoon. I pulled the red trolley emergency cord and pushed the door down but I couldn't get it closed (locked). Why not?
IF THE OPENER IS IN THE OPEN POSITION THERE IS NOTHING TO LOCK IT IN THE CLOSED POSITION.
YOU CAN UNPLUG THE UNIT AND PLACE A VICE GRIP ABOVE A ROLLER ON THE TRACK. THIS WILL SECURE THE DOOR UNTIL POWER COMES BACK ON - DO NOT LEAVE THE UNIT PLUGGED IN - IT COULD BE DAMAGED BY A POWER SURGE WHEN THE POWER COMES BACK ON (ALL ELECTRONICS IN THE HOUSE SHOULD BE UNPLUGGED) ALSO IF YOU FORGET AND PUSH THE BUTTON THE VICE GRIP WOULD CAUSE THE DOOR TO COME OUT OF THE TRACK, MAKING YOUR CURRENT ISSUE SEEM SMALL.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light-master garage door opener - re-engaging the motor after dis
The chain and bracket should automatically engage the door's bracket just use the remote as normal,
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener will not reverse
FIRST YOU NEED TO RESET THE CHAIN .
Unplug power
Release the door from the opener close the door manually. take the chain loose and slide the traveler down to reengage with the trolley. Plug in power, run the unit with chain off untill it completes a clockwise cycle and stops. reconnect the chain and set tension.
Adjust the chain tension.
If it still moves 6-8 inches and flashes 5 times. the problem is in the rpm sensor.
Full diagnostics are in the owners manual - FREE at
http://help.chamberlain.com/help/en-us/InstructionManuals
Oct 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 950CB Remote Control Logo
81 people viewed this question
Top Chamberlain Televison & Video Experts
Raj Patel
Are you a Chamberlain Televison and Video Expert? Answer questions, earn points and help others
