Question about Garden
Why would a reasonably new mower belt be slipping
  • 2,760 Answers
Could be a few things, (1) is the belt designed for use on mower, car fan belts are not the same material (2) was new belt installed to tight to begin with if so it will stretch out and slip ( 3) is mover over used to it's designed purpose , I once new a guy that used his craftsman mower to move his 22 foot boat/trailer around he went thru lots of drive belts
and last but not least that cheaper belt might not be the best deal when getting replacement parts , all mine have 30 dollar kevlar belts (yes the bulletproof stuff) installed on them and i've no problems with belts
Posted on May 16, 2014
4 Suggested Answers
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: My deck belt on my 54 inch craftsman mower keeps
have you solved your problem yet? was the belt bought from sears or somewhere else? do you have a diagram for the belt instillation? these are a few thing i would ask you. i belive your belt is a 196103 style belt the problem with this is that there several manufactures that call there belts a 196103 some ar 11/16 other are 5/8 wide and the range in length from 147-1/4 up to 148-1/4. next if you reverse the install order around the center spindle and tensioner it will have too much slack if these two things aren't your problem i would look for worn pulleys especially in the shaft of the bearings or a misaligned/bent pulley
Posted on Aug 20, 2010
  • 3911 Answers
SOURCE: belt slips on bolens riding
there is a belt which drives the deck/blades, and another belt which transfers power to the transmission to move the mower. you do not specify which belt, but as they both have a tensioner, you need to locate the pulley which removes the slack from the belt and replace it and the spring which provides the tension. you had to release this tension in order to install the belt so you know exactly where it is. oftentimes a close examination will reveal that the belt was not put back on correctly. if it was slipping already, you replaced the belt and it is no better then replace the tension spring. if it was working fine and the belt broke due to wear and now it is a new belt and slipping i would closely examine the path of the belt all the way around and make sure it is in right. often times there are small dowel shaped steel keepers and guides which are supposed to hold the belt in but the belt has inadvertently been routed around them which makes it slip.
good luck
Posted on Apr 13, 2011
Drive belt is slipping on a pull. Replaced with Cub Cadet Belt. What else could be wrong?
Sounds to me that the belt has stretched,to a point that it slips. Most drive belts,on a riding mower hasn't any adjustments,so the way to repair this problem is, to purchase a new belt. Hope this information helps. B. Locke
Oct 03, 2015 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Hayter 56 pro lawn mower will not drive with weight on roller I have replaced belt
Sounds like the belt is slipping
Is your new belt the right one or is it the same length as the old worn one.
You might try spraying the belt with a belt dressing and that may work if its the belt slipping.
Another thought is your belt tightener working properly.
Just throwing out ideas to check.
Nov 12, 2014 | Garden
Mcculloch lawn mower why would a reasonably new mower belt be slipping
Could be the tension on the belt is incorrect, or a worn pulley, or a pulley that is not running true due to bad shaft bearings.
May 16, 2014 | Garden
Drive belt slips on Husqvarna YTH21K46 riding lawnmower, installed new drive belt and it slips. mower is 2 years old
I had this same issue. New belts and correct routing did not solve the problem. The issue with my mower was the tabs that come off the frame that you bolt the transaxle (the drive for the rear wheels and axle) had almost completely torn/cracked away. This allowed the transaxle to tilt forward under a load and slip the belt off the rear drive pulley. You see no mention of this at the dealer or company sights. The tabs are so thin this is going to happen, in my opinion, in time. I reinforced this area with 1/4 inch angle iron and have had no further belt issue.
Apr 21, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Belt slips on bolens riding mower has new belt
good luck
Apr 13, 2011 | Garden
Craftsman mower keeps breaking primary mower belt
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Jul 29, 2010 | Craftsman Garden
Mower drive belt keeps coming off, why
Your drive belt could be coming off for many reasons oil on the pully making it slip off,or it could just be worn out and strecht out but the main reason could be is your belt is to loose and this could mean either you motor is loose and moved back or you rear end is loose and move up or even both. I am no pro so I am just going by experiance so my suggestion to you look under your mower and see if you belt is loose and also look and see how worn it is and if it is some pros will give free advise right over the phone of what you should check or they can tell you the exact problem.
Apr 19, 2010 | Garden
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
