Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
I have a cub cadet lt104 and we replaced the battery and solenoid and it won't start
  • Joel Friedenberg May 17, 2014
    Hi Gayling Fox, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Does the engine turn over, but it won't start, or when you turn the ignition switch, nothing happens. Please explain exactly what happens/ doesn't happen when the key is turned.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Wont crank or wont start. 2 different things...
wont crank, in this order: check fuse, brake switch ( adjustment and operation ) and then ignition switch
wont start but does crank: check for spark, yes then check fuel shut off solenoid. no, disconnect kill wire to coil and check again, still no, coil is issue, if yes after disconnecting kill wire suspect a safety switch
Posted on May 17, 2014
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CUB CADET LT 1046 WONT CRANK
If the head lights come on, check the PTO switch connector. Very often the connector comes loose.
If no headlights, check the fuse. If blowen look for shorted wiring: Mice may have chewed wires inside the flywheel cover; check the head light cable. Often it rubs through at the hood pivot; check the lead on the carburetor solenoid, sometimes they rub through at the wire ties holding the red lead to the solenoid.
I am a certified Cub service tech,and those are the common problems I have run into.
Oh, one more thing, make sure the battery is good. Load test it or have it load tested if you don't have a tester. Don't just check it with a volt meter. That wont load the battery to check for dead cells.
Jul 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
May 02, 2009 | Garden
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
