Question about OKI MICROLINE 490 Printer
How do you run a test page for an OKI ML490 printer
5 Suggested Answers
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
ginko
  • 19396 Answers
SOURCE: I need to know how to print a test page on a Oki
Try Select, or Shift and Select, or Shift and Print.
See reference manual in here.
Posted on May 18, 2009
  • 1584 Answers
SOURCE: how to printer test page a oki 520
Go to Start / printers and faxes / Right click on print icon / properties / print test page.
Posted on Feb 17, 2010
MedManHelp
  • 55 Answers
SOURCE: I have the oki microline
use the -r print option in the name of the printer
ie. "printername -r"
Posted on Jul 27, 2011
Just prints blank pages.
try running a test(demo) page from the printer first if it prints check your drivers
Sep 06, 2015 | OKI C9800hn Led Printer
Printing very light Okionly B410d printer usesblack toner cartridge
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry C3300n Laser Printer
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
How to printer test page a oki 520
Feb 17, 2010 | OKI MICROLINE 520 Matrix Printer
PRINTS NOT ON DEMAND
The types of printers that you have actually should be assigned to a free port, you cant setup 2 printers on the same port. check at the back of the printer the physical attachment of two printers the OKI and the Epson, if Oki is set to lpt1 then assign port from printer properties for oki to lpt1, and lpt2 on epson. 1 printer- 1 port, so by then check if the box for enable bidirectional support is check, remove the check mark from the box by clicking on it then hit apply then try printing a test page then try printing from application.
Apr 08, 2008 | Epson TM U325PD Matrix Label Printer
3410 Oki printer
If your print fades in then out every 5-6 lines, your platen probably has flat spots on it. This can be caused when someone forget to perform an alignment on a PH.
To run a test page you can power off the printer. Hold down the LF key and power on at the same time, this will print a self test.
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
OKI MICROLINE  490 Printer Logo
53 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
