Question about Cub Cadet Riding Lawn Garden Zero Turn Tractor
How come cub cadet 7254 runs rough needs choke pulled out all the way
  • 25 Answers
Sounds like you have a carbrator that is gummed up. It will need a cleaning and a possible rebuild kit, depends on how bad it is.
Posted on Oct 29, 2014
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Posted on Jul 10, 2010
  • 3074 Answers
SOURCE: wiring schematics for 2007 cub cadet lt1045 need
this should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 04, 2011
rockmeister
  • 2047 Answers
SOURCE: when i start the lt1045 cub cadet riding mower it
Hello there, there are 2 main things you should check concerning the issue. Rough running is usually caused by carburetor or injector system needing servicing and also a dirty, soaking or faulty spark plug. The combustion system being dirty makes the flow of running such that the unit smokes and changes sound and runs as though it is running forcefully and this sounds rough.
Secondly the spark plug is meant to co-ordinate the electrical parts of the engine which assist the engine to run. If any of these are not running fine then the engine does not function fine and sounds rough.
Another possible cause is a leakage in the exhaust system. This explains the smoke from the front more as if there is a leakage in the exhaust channel the smoke could come from the front exhaust.
Check all the above mentioned one of them is your culprit.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Posted on Aug 13, 2011
  • 6468 Answers
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
Posted on May 14, 2012
Did you mean: i have a cub cadet 1040 ltx that is running rough and loud?
Head Gasket possibly
You should be able to find out where
the noise is coming from
Oct 11, 2014 | Cub Cadet Garden
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
25 hp kholer engine will not stay running without the choke on
if the fuel is newer than 30 days you need to rebuild the carb if not try fresh fuel first
Aug 11, 2012 | Cub Cadet Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet 2156 after ru8nnung for about
have you tried cleaning the spark plug and the air filter?
Sep 14, 2009 | Mtd Garden
Cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
May 10, 2009 | Garden
Cub Cadet Riding Lawn Garden Zero Turn Tractor Logo
82 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
