Does cleaning ac filters stop it from producing condensation?
    Genius:
  • 1,342 Answers
A key goal of AC is to remove humidity as it cools else it would be like living in a cave. You do n0t mention where the condensation is located.
Posted on May 17, 2014
2 Suggested Answers
  • 230 Answers
SOURCE: AC window unit was tripping
My guess is that you have a dirty outdoor coil.
Posted on Jul 12, 2011
The coils jeep freezing up I have cleaned the filter
usually means Freon charge is low, you might have a leak..... also, filters don't catch everything. over time what gets past the filter can be trapped in underside of the evaporative coil on top of your furnace..... outside condenser coils may be caked with debris, improper air flow threw coils can produce liquid Freon back to evaporative coil causing it to freeze..
hosing the condenser down will resolve freezing up too
Oct 04, 2015 | Filter Heating & Cooling
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
Split system AC has pungent brussel sprout odor
clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Apr 17, 2014 | Coleman Heating & Cooling
I went downstairs to start a load of clothes and noticed water under my furnace. My A/C is running and I had it cleaned a few weeks ago and the unit itself had to be charged. It has run beautifully and...
Hello, most likey if the unit is cooling and there is no visible ice on the suction line then it is probably a cloged condensate line that will need to be cleaned.
Jul 11, 2011 | Heating & Cooling
How to stop leak from Dometic "Brisk air" RV AC into the living area?
  • Start with the condensate drain. Your air conditioner collects condensate water from the evaporator (moisture that was in the air condenses and turns into water on the coil) where it then drains into a pan and then outside of the unit. Look for a drain and clear the blockage. If you have a wet/dry shop vac, you can vacuum out the drain area.
  • Make sure your air filter and your evaporator coil are clean. Clean as necessary.
  • Inspect seals and repair as necessary.
These are the first things you want to do and will, in most all cases, correct the problem you are experiencing. :-)
May 07, 2010 | Dometic Rooftop RV Air Conditioner
MY split ac is leaking water from the wall unit, it has been doin
Usually an AC unit builds up condensation. If you have a drain hoole or hose that is clogged up therefore not allowing the build up to drain off it will spill over the top of whatever housing the condensation goes into. If you can look for that issue first.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
When I start my ac it works unless it's working really hard for a long period. In this case it runs but stops cooling. Any ideas on what the problem could be?
I would make sure that the outside coil (condenser) is clean. It sounds as if it overloads on hot days. Make sure the inside filter is clean. too.
Jun 14, 2009 | Haier Energy Star ESA3183 Air Conditioner
My ac stopped putting out cool air on a hot day. I turned off the ac and replaced 2 dirty filters and waited 4 hours to turn back on but the air does not seem cool. Did I not wait long enough time for it...
check to see if the fan is working at the condensing unit. if it is, check that the fan is pulling heat off the unit as it should. make sure the cage is clean. no restrictions as far as air flow. clean . check duct work for leaks. inside, if you replaced the filter/s. the evaporator is dirty. call a prof,
Apr 25, 2009 | Ruud UBHC Air Conditioner
No hot air is being produced from my Zanussi TC 180 condenser dry
what make is it?is it a top lint screen or inside?
Mar 31, 2009 | Dryers
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
