Would a home a/c stop dripping condensation after a tune-up WAY, WAY overdue?
It's a Trane XE80 that used to drain out on the flowerbeds, last week, dude came & did a maintenance check-clean'd it all up...I noticed it's not dripping from the condensation pipe like it did since my husband broke it.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 62 Answers
It should drip. That's the humidity from your house. Call them out again to have them verify the drain pipe is clear. Tell them you think they did something wrong. If it doesn't drain right, it will pool inside the unit and cause the internal AC panels to rust if the drain pan (below the condenser) overflows. Or worse, it might be a source for mold to grow inside the system. The later being unlikely, but not impossible.
Posted on May 16, 2014
Testimonial: "Thank u very much...that's what I thought !"
  • 400 Answers
SOURCE: My Daewoo DSB 091L unit has started to drip
Make sure that the flexible pipe is securely connected to the drainpan, it can come adrift and cause leaking. The way to check this is to make sure everything is dried out completely. Then open the front grill and carefully pour water so that it goes only into the drip pan. Pour slowly so that you do not overflow the pan. If water is coming out on the outside and you have no leaks on the inside, then you can rule out the perished or disconnected drainpipe theory. In this case your unit may be short of refrigerant causing excessive run time and a freeze up of the evaporator.
Posted on Mar 31, 2009
  • 12 Answers
SOURCE: Dripping water from the pvc drain pipes of 2nd story eaves.
yes, that is your emergency drain pipe. You need to have the a/c drained cleaned out. It is probably jammed up with algea. A professional should be called to blow it out. or get ahold of your Mr. Fixit buddy. If you leave it like this your drain pan will eventually rust out and cause major interior damage to your home.
Posted on May 14, 2009
  • 4 Answers
SOURCE: i replaced the Trane condenser cool my house down
You have the contactor wired improperly. You need to go to the low voltage wires coming from the thermostat. The wire combination you gave sounds like you are looking at the high voltage coming off of the capacitor. If it wont shut off you most likely have the red and yellow wires crossed.
Posted on Jul 30, 2009
roniecon
  • 6927 Answers
SOURCE: Condensation water is not draining properly on
Yes,remove the ac unit from the window,and clean it out with a water hose out side,remove all debris from inside the unit,and tilt water out of unit.Make sure there is nothing in the way of the drain,and when the unit is put back in the window,make sure it has a very good tilt outward so the water will for sure flow outside,not in.If this was helpful,please rate,thank you.
Posted on Jun 24, 2010
  • 96 Answers
SOURCE: Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
Posted on Mar 06, 2011
Trane xr90 leaking water from behind inducer
You have a condensing furnace, clean out the condensate drain line.
Nov 30, 2013 | Aprilaire Heating & Cooling
Water is dripping from the top into the fridge in the back is frozen up and condensation is forming at the top of the fridge ceiling...dripping down.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 10, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Noticed a trail of water when I got home from work tonight . all guages are reading fine. live in new england and very heavy fog tonight. there are no noticable problems and just had a tune up last week
did you have your air conditioning on? if so, it is condensation dripping from the evaporator core, underneath around the firewall area. this is normal.
Jun 03, 2010 | 2005 Dodge Grand Caravan
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Mar 23, 2010 | Heating & Cooling
Leaks water out the front about once a week how can I fix ?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Dec 10, 2009 | Whirlpool Refrigerators
Condensation is dripping down from the freezer into the refridgerator and freezing.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 05, 2009 | Refrigerators
Have frigidaire model FRT 18B5JB1, the space below the crispers fills with water and spills out on my floor about every week and a half..there is no drain, no condensation on the walls..help!!
Sep 04, 2009 | Refrigerators
Water leaking from refrigerator
If you just want to clean it you may can access it from the rear behind the cardboard backing. If it's overflowing your water filter may be stopped up or you may have had an excessive amount of frost one time.
Jul 09, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
