Question about Apex Digital AT2408 24" TV
At2408 tv will not power on just has a beeping sound when plugged into outlet. what needs to be done?
Don't know if needs reset or what
    Top Expert:
  • Apex Digital Master
  • 75,471 Answers
Check and replace damaged component/s at it main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Posted on May 17, 2014
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 25, 2015 | Refrigerators
My samsung frige, french doors keeo ringing
Mar 19, 2015 | Samsung Refrigerators
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
Jul 01, 2013 | Lands Phones
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
TV will not power up, no lights blinking just a continuous beeping sound
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Jan 23, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Apex Digital AT2408 24" TV Logo
44 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
