Question about Boating
Where do I disconnect the shift linkage to take the lower unit off of a 1983 Johnson 35 hp. I disconnected it behind the water inlet but lower unit will not come completely off/
    Top Expert:
  • 44,304 Answers
There are about 5 bolts that need removed .one is kinda hidden under the little circular steering skag , and there will either be a link on the shifting rod midway down or the entire rod will need unhooked at the top. neither place being easy to get to . good luck
Posted on May 18, 2014
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
I need to disconnect the shift linkage of a 1983 Johnson outboard motor. I already disconnect at the water inlet. The lower unit still will not come all the way down.
some shift rods unhook midway thru the leg ,others you unhook at the top and the entire rod comes out . caution getting the shift rod lenght the same as when removed is critical or you will have shifting problems.
May 16, 2014 | Boating
1989 johnson 25 hp outboard water pump replacement ? shift linkage issues.
Line up the water pump housing with the drive splines and look straight down on it all -there will be a clearance cast in the pump housing some where. It's a matter of perspective. Or you have the wrong pump.
Jul 29, 2012 | Boating
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
VERY LOW WATER PRESSURE TO THE LOWER AND UPPER SPRAY ARMS. FILLS AND EMPTIES NORMALLY
Hello there:
i will post this solution in 2 separate post due to the length of it ok
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
ools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
Oct 16, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
How to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Dec 30, 2009 | Boating
Need to change impellor on 1988 70 hp johnson how to please
first go to www.crowleymarine.com to get a picture breakdown of your water pump. website instruction, click on part catalog tab, click on omc Johnson and evinrude tab. choose product line, year tab, engine size, choose model. click on gearcase. the picture showes all parts you have and the correct order they go. ok now we are ready to disasemble the lower gearcase from the motor.(1) trim the outboard down using the tim and tilt system (2) shift remote control into forward gear, this lines up the shift rod so you can reach it. a picture of the linkage is refernce number 50 on the picture from crowleymarine.(3) Remove engine coul, under the carburators you will be able to see the shift rod. if you can't see it follow the shift cable to the shift linkage to the shift rod(4) the shift rod has a hole in the top, that a long screw goes through, connecting shift rod to shift linkage. remove this screw(refer to picture downloaded)(5) again refer to the downloaded picture remove these bolts that i list. number 66 there is 4. #77 there is 1. pull off #76 trim tab.#68 there is 1. #70 there is 1. lower unit will drop after you remove all bolts. remove the impeller housing. look at impeller you will see the fins are bent in one direction. put new impeller in with fins bent in the same direction. reinstall housing and gear case following my dirction in reverse order.
Oct 05, 2009 | Boating
1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Mar 28, 2009 | Boating
Boating Logo
105 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
