Question about Garden
John deere l120 mower deck just quits after 20 min mowing or may work ok for 4 hrs?
  • 2,760 Answers
This one your gonna need a test light to see what the problem is (they sell em in autoparts stores for about 6 bucks) use probe from test light to probe connector that goes to pto clutch when symptom shows it self if not one of the two wires on plug produces a "light" then your gonna have to work backin wiring to see where it stops (oohhh ya do this key on engine off mower deck engauged) and somebody sittin in seat too (i use my dog Barney he's heavy enough to set seat switch off) and if ya get a good light on at least one of them wires then sorry your gonna have to replace pto clutch
Posted on Jun 05, 2014
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
nova2nv
  • 197 Answers
SOURCE: I have a john Deere L120 the mower deck quit
Check to see if your RIO switch wiring is good then check RIO switch to see if it out of adjustment.
Posted on Nov 13, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
  • 66 Answers
SOURCE: My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
Posted on May 30, 2010
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
I have a probably 20 year old John Deere 130 lawn mower the mow deck is stuck in the highest setting and will not lower, how do lower it, Thanks
a 130 that's 20 years old , does this one have a black deck or a yellow deck , the black deck ones used a hydraulic cylinder (commercial model) and the yellow deck models used a grab bar just infront of the seat , you need to squeeze the handles together to get catch to release , then it should just fall down to it's lowest setting , that is if it's not rusted in place , a few squirts of soaking oil will do wonders on this
Mar 24, 2015 | John Deere Garden
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
The blades only turn when the electric clutch is engaged. Sounds like you may have a short in the wiring possibly at a terminal that is shutting down the clutch. Or it might be in the "reverse button" you have to push to keep the blades turning when you back up. Try holding in on the button when it stops and see if they start back up. I think it's definitely in the wiring somewhere.
May 16, 2014 | Garden
John deere l120
If the deck is bet drive, check for worn or slick belt. If it has a electric clutch check it.
The left blade on my John Deere LT155 stopped working
Besides the drive belt, there is a timing belt inside the mowing deck. The left blade is run by the timing belt. I imagine the timing belt is broken.
Apr 27, 2012 | John Deere Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Blades will not ingage
your electric pto clutch switch is bad replace it
Nov 14, 2008 | Garden
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
