Question about Frigidaire GLGQ2152ES Gas Dryer
The problem is that the display for the ?estimated time? do not show the time immediately I start the dryer cycle, instead of it shows some short green lines turning around the display and after some time it shows the number for the ?estimated time? almost always it occurs and the end of the cycle. Is that a normal operation?
  • 64 Answers
Yes the computer is tring to figure out whats left to do
Posted on Jun 23, 2009
WHAT DOES CODE AD MEAN ON THE DRYER
If your dryer is set to "auto dry" the display will show AD initially and then may show a number which is the estimated time for the clothes to dry in auto dry mode. The display may also show CD (Cool Down) and DN (Done) during the cycle.
Feb 27, 2015 | Washing Machines
Estimated time remaining readout shows AF instead of the time left. It is a Kenmore 700 series dryer
AF stands for Algorithm Failure, which means that there is something preventing the dryer from calculating the remaining time. Try cleaning out the dryer drum and lint screen completely, then run the dryer with just a dry towel.
Feb 20, 2015 | Kenmore Dryers
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
How to turn off demo mode?
Good Morning Friend,
I understand you want to turn the demo mode off of your Electrolux dryer, model# EWED65H. To deactivate the demo mode in your appliance, please try the following:
    1)Turn the cycle knob to the last cycle on the right.
    2)Press the start button and immediately afterwards press the cancel button.
    3)Within 10 seconds, wake up your appliance by pressing the start button once.
    4)Immediately, press and hold cancel and the right most key under the display, together for a minimum of 6 seconds. DEMO MODE will no longer show in the display.
    5)If a 3 prong power cord (120V cord) is attached, remove it and attach normal 240 V cord.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EWED65H Dryer
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Shows dashes for some cycles and doesn't start
Try resetting it by shutting power of and back on. Or just unplug it and plug it back
Apr 10, 2014 | Dryers
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire GLGQ2152ES Gas Dryer Logo
71 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
