Question about Toys
Why a bobcat 331-c travel is slow on right side forward or backwards
    Problem Solver:
  • 10 Answers
Check pressure at spool valve input.If the pressure is ok then look at the flow control valves (sometimes refered to as compensating valves)
Posted on May 16, 2014
3 Suggested Answers
  • 520 Answers
SOURCE: I have a bobcat 773T
the screeching sound could be a belt slipping. there should be a neutral adjusment on the valves that the sticks are attached to. its just a matter of finding true neutral.
Posted on Jan 16, 2011
SOURCE: left side dont pull properly
What is the make and model number of the toy that you are having problems with?
Posted on Dec 31, 2010
Have a 763 bobcat n right side wheels won't go forward any ideas on what this might b??
Broken chain in drive line on right side or chain sprocket.
Oct 02, 2016 | Cars & Trucks
How to remove front idler on bobcat 331 mini excavator
Bobcat 331 Mini Excavator, Front Idler Assembly
www.loaderpartssource.com/bobcat-331-mini-excavator-front-idler-asse...
Loader Parts Source, Inc. offers this Front Idler Assembly for Rubber Tracks (W/ Holes in idler) for replacement on the Bobcat 331 Mini Excavator. Serial Number ...
Bobcat Idler: Construction Equip Parts ' eBaywww.ebay.com/bhp/bobcat-idlereBayBobcat 325, 328, 331, and 334 Front Idler - Undercarriage, Mini Excavator, ... BobcatT140 T180 T190 T200 T250 T300 T320 T650 T630 T750 864 Front Idler ...Undercarriage Parts Can Help You:Eliminate Unwanted Machine Downtime.Front/Rear Idlers - Mini Excavator Partswww.miniexcavatorparts.com/productcart/pc/viewCategories.asp?...14Aftermarket front and rear idlers are available for Bobcat track loader and mini excavators, Kubota miini excavators, and ... Aftermarket Bobcat® Front Idler - Bobcat CTL ... Aftermarket Idler - Bobcat 325 328 331 334 430 335.
Dec 25, 2015 | Mini Cars & Trucks
My reverse goes faster than my forward what's wrong
Sounds like the throttle is connected backwards. The parking brake maybe hanging up. if the scooter is run for 10 mins forward, then carefully check with your hand that the parking brake is warm and not hot. Hot indicates brake slowing you down and making the motor work too hard. For other answers to Scooter Problems goto my free app.
Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Aug 07, 2015 | Elite Pride Go Go Traveller 3 Wheel
When push I push to go forward its real slow and backward runs fast
strange if no one has played with it it could b youre little control box..........cheers.
Aug 06, 2015 | Elite Pride Go Go Traveller 3 Wheel
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
Feb 20, 2015 | Bobcat Garden
User needs to use left hand for forward and reverse and would like wires switched
hi, you need to expose the throttle pot that is the pot attached to the lever you move to go forward or backwards, normally it a top cover known as the tiller cover, once you done that you see the throttle pot has three legs with coloured wires attached now you need to crossover the outside wires, not the centre one, by doing this you're are moving the reserve to the right hand side and the forward to the left hand side.
if you require more assistance then please let me know..
that's it,
regards
please give me feedback
Dec 17, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My typewriter doesn't move forward every time i type ... what do i do?
You may need to reset your margins with the margin set button on either side of the roller. If the carriage is stuck right in the middle and will not move forwards or backwards, there is a little toggle button right under the carrier return handle. You may have to turn your TW on it's right side to see this small hidden button. This locks the carriage down for travel. Find that little toggle and move it.
Jul 30, 2011 | Olivetti Lettera 25 Typewriter
I have a bobcat 773T with the Kubota engine. It is a 2001 model. All of a sudden when I move the machine forward or backward it continues going forward or backward slowly and sometimes it will either turn...
Jan 16, 2011 | Toys
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Oct 18, 2009 | 1994 Jeep Grand Cherokee
Hyd controls get hard after machine has run ten
You got a pressure crossover problem there , main pump pressure is leaking into the servo system I would suspect the pump.
Apr 10, 2009 | Garden
Toys Logo
121 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
