Question about RTO Bernzomatic Brushed Nickel Patio Heater
BernzOmatic ph3200n I need to replace the igniter switch, Part Number LA128A (L16A)
What is the part number for the control knob for the Bernzomatic Patio Heater model # PH3250N?
Bernzomatic does not provide nor sell replacement parts for their products - they consider them disposable.
If the plastic knob is the only piece you need, Amazon sells a few replacement knobs for patio heaters. I searched Amazon with the terms:
replacement knob patio heater
Nov 01, 2017 | Pool & Spa
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
Bernzomatic will not light
if tank line on tight check line to ignitor
Dec 14, 2012 | RTO Bernzomatic Brushed Nickel Patio...
Bernzomatic patio heater will not light?
these had problems with purging air out of the system.that may take a while and make sure you have spark.
May 01, 2012 | RTO Bernzomatic Brushed Nickel Patio...
I have a bernzomatic 94499 patio heater does anyone know where I can find an owners manual? The pilot will light but not the burner? There is a brass fitting towards the back that seems to be the burner...
You need to replace that brass piece . Its a thermocouple. Bernzomatic does not sell a replacement thermocouple, however I had success using Mr. Heater 12.5" replacement thermocouple. You can buy it from Ace hardware. Its also sold on Amazon.
http://www.amazon.com/Mr-Heater-12-5-Thermocouple-Heaters/dp/B000BP7LJ2/ref=sr_1_1?ie=UTF8&qid=1325746531&sr=8-1
To remove the nut on the old thermocouple I use a 13/32" socket. I think a 10mm would work also. Must be a deepwell socket. The new Mr. Heater nut takes a 7/16" socket. The old thermocouple runs to a black plastic piece with soldered on connectors. I removed this piece entirely. The electric igniter's ground wire runs to one of the bolts, so that must be put back after the piece has been removed. I did make the effort put the white cloth cover over the new thermocouple. I took it off the old one. I barely fits over the nut, and must be worked on like a Chinese finger trap but it will go. Good luck.
Sep 07, 2011 | RTO Bernzomatic Brushed Nickel Patio...
Need Bernzomatic Heater Knob
most universal kitchen, bbq,small appliance replacement knobs will fit ur application
Mar 03, 2010 | RTO Bernzomatic Brushed Nickel Patio...
We have a problem with the starter. Once we start
Bernzomatic Heater will not light. Full tank, but not flame; however, I can hear the igniter trying to work.Could there be spider webs present? Where do I look to find them?
Jul 09, 2009 | RTO Bernzomatic Brushed Nickel Patio...
RTO Bernzomatic Brushed Nickel Patio Heater Logo
228 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
