Question about Stainless Patio Heaters - Steel Deluxe Residential Outdoor Patio Heater
BernzOmatich3200n I need a igniter switch. part number LA128A (l16A)
    Genius:
  • 1,114 Answers
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
Posted on May 16, 2014
I lost my keys to my 2011 Honda rancher 4-wheeler. I need the # off the ignition switch but I don't kmow where it is
you mean number on the ignition barrel
for the key code number
if not found near the key insertion point
honda ATV dealer or lock smith can help
remove the.....ignition, loom , barrel
take that to them
Oct 04, 2016 | ATVs
How would I bridge the ignition wires to bypass the key
it require wiring diagram at ignition portion just look wire color or number and watch it at ignition switch . at ignition key's ON positon what number or color of wire it connects is the answer of your question .
Apr 06, 2016 | 1992-2001 BMW R1100RS Brake Pads
Ignition switch diagrams
12V CONSTANT YELLOW Ignition Harness
STARTER WHITE/PINK Ignition Harness
IGNITION RED/LT. GREEN Ignition Harness
ACCESSORY GRAY/YELLOW Ignition Harness
SECOND ACCESSORY BLACK/GREEN Ignition Harness
also this might be of some interest to you if you are having ignition switch problems just look up this FORD ignition switch recall
NHTSA recall number 96V-071).
Aug 04, 2014 | 1990 Ford Taurus
Repir suzuki boulevard ignition
Typically, there is a ring that screws onto the front of the switch which mounts to the holder from the back. Remove the ring, the switch falls out. I dont know if yours is "typical", however.
Better yet, take your serial number to your Suzuki dealer, ahd he or she can cut you a key based on that number. For that matter, so to can a good locksmith. No need to remove the switch.
Dec 18, 2012 | 2007 Suzuki Boulevard
How do I find the part number to my ignition switch on my 1995 zx6r f1 I lost my key and need to get part number so Kawasaki dealt can cut me one
The dealer probably is looking for a key number that came with the bike when it was newly purchased. If you are not the original owner then you probably don't have that number. If anyone know where that number is, it would be the dealer (they could tell you). More than likely the best thing to do is to remove the ignition switch and take it to a lock smith and they can most likely make you a key. Removing the ignition switch may not be that easy because sometimes they have special theft proof bolts in it that need a special driver to remove (ask your dealer). The only other thing that you can do is buy a complete lock set from the dealer or froma salvage yard but that is not always cheap.
Nov 15, 2012 | Motorcycles
I lost my ignition key? were can i get it or do i have to change the ignition switch?
I dont know if your bike has a number nere the ignition hole or not but if it does go to ebay and look for spare keys and match the number up with the key if it does not have a number then youll have to get a new ignition switch.
Aug 08, 2010 | 1994 Honda CBR 600 F(2)R
How do I unlock ignition switch, key will not turn in ignition switch
Either your tumblers in the lock are dirty or broken or your key does not fit the lock. If you have an original key it has a key number on it. The bottom of the ignition switch should have the same number on it (A12345,Bxxxxx,Cxxxxx,Dxxxxx,or Exxxxx). If the numbers are different you need to get the other key made at the dealer or locksmith. If the switch is broken you will probably need to buy a new switch.
Jun 26, 2010 | 1993 Yamaha Xv 250 Virago S
Ignition switch for diesel engine. Lost key
if u notify dealer with vin number they should be able to cut u a new key --if ur key had a electronic chip in it still would need to notify dealer ----if u want to replace ignition switch the switch runs about $130 if electronic more -then u need to add on the price of installing it $65-75 an hour labor cost-- some not many lock- smiths do automotive ignition keys [non electronic ] from vin number
Feb 25, 2010 | 2004 Volkswagen Touareg
New Ignition Cylinder doesnt click in?
Lock Cylinder Functional
Removal
  1. NOTE: The following procedure applies to vehicles that have functional ignition switch lock cylinders (11582), lock cylinder keys are available for these vehicles or the lock cylinder key numbers are known and the proper key can be made.
    Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Turn ignition switch lock cylinder to RUN position.
  1. Place a 3.17 mm (1/8-inch) diameter wire pin or small drift punch in hole in lower steering column shroud (3530) under ignition switch (11572). Press retaining pin while pulling out on ignition switch lock cylinder to remove it from steering column lock cylinder housing (3511).
Installation
  1. Install ignition switch lock cylinder by turning it to RUN position. Insert ignition switch lock cylinder into steering column lock cylinder housing. Make sure ignition switch lock cylinder is fully seated and aligned in interlocking washer before turning ignition switch lock cylinder to OFF position. This will permit cylinder retaining pin to extend into steering column tube flange hole.
  1. Rotate ignition switch lock cylinder, using lock cylinder key, to ensure correct mechanical operation in all positions.
  1. Connect battery ground cable.
Apr 03, 2009 | 1995 Ford Taurus
Heating & Cooling Logo
135 people viewed this question
Top Stainless Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Stainless Heating and Cooling Expert? Answer questions, earn points and help others
